Hard Starting 51 B
bryani289swmi
08-29-2004 18:12:41
I've got a 51 B I picked up from my wifes family a year or two ago and I'm starting to play around with it. Only problem is that it is a terrible hard starter. It will pop a few times when it's turned over but doesn't catch and run. It runs ok when running, but not great, it doesn't seem to be running too rich since there's not much smoke as an indicator. I'm guessing the timing is a bit off, any thoughts and suggestions on what to try are appreciated. Thanks.
buckeye al
08-30-2004 08:51:11
 Re: Hard Starting 51 B in reply to bryani289swmi, 08-29-2004 18:12:41
First a question.... Does it have a distributor or a magneto? If a magneto, check it out. A troublesome Magneto will cause starting problems yet the tractor may run fine once finally started. The faster they turn the better they function (to a certain extent) and running is so much faster than starting, the troubles they have at cranking speed no longer give you headaches.
bryani289swmi
08-30-2004 07:53:51
 It has new plugs and gas in reply to bryani289swmi, 08-29-2004 18:12:41
NT
Lem Fl
08-29-2004 22:06:32
Try replacing the sparkplugs
Jeffro
08-30-2004 04:27:25
 Re: Hard Starting 51 B in reply to Lem Fl, 08-29-2004 22:06:32
I have a 50 B and had one hell of a time getting it running right. The main reason was that I was not running the right kind of gas. Get some low-octane stuff, NEW GAS and it will run fine. I have also tried mixing a little (@ 4 oz. per 10 gals.) outboard motor oil with the gas-this is supposed to help with the top cylinder lube. Given that gas now is unleaded. The main problem I was having was that the gas had just gotten old and wouldn't burn well. If any old stuff is in there, just drain it and use it in a mower. On other thing-always shut the engine off by turning off the fuel at the gascolator. Some people choke it down to shut it off, but this can result in a cylinder full of fuel and possibly a wet plug and severely hard starting.
-Good luck-
Jeffro
