BR wheels
T S
08-29-2004 17:53:43
How can I identify the correct steel wheels for a BR? What would the numbers be? Are they common or unique to the BR? Thanks
Duane Larson
08-29-2004 20:55:16
 Re: BR wheels in reply to T S, 08-29-2004 17:53:43
TS,
All BR/BO's used JD 1221R flat steel rears, casting number JD1221R (but the casting number only appears on wheels after about 2/41). It has the JD "zig-zag" center hub, 10 spokes, 40" dia by 8" wide x 1/4" thick steel wheels. The center has the 6-bolt hub, and the wheel is reversible. The GPs and ARs used different wheels, so far as I know they are unique to the BR/BO.
Some later parts books refer to a 48" rear wheel, but I believe that is an error as they would not fit very well under the fender.
