JD 112 w/ Tecumseh
JTWalk
08-29-2004 16:55:31
Recently acquired from a neighbor. Changed head gasket & rebuilt carb. engine runs great,but in 4th(or any)gear.there is very slow accleration(granny gear) & variator shifter is not operative,but rpms stay constant. Every once in a while the tractor will accelerate,but as soon as the clutch/brake pedal is used to slow down. The tractor will stay at slow accleration(granny gear)Is there an adjustment for this ? Thanks.
buickanddeere
08-29-2004 20:43:26
 Re: JD 112 w/ Tecumseh in reply to JTWalk, 08-29-2004 16:55:31
If there is any rust on any moving/sliding parts or binding. The variator won"t move on it"s own. Also look at the springs and make certain the havn"t been damaged or had the wrong ones used for replacements. I put a heavier spring in one of my son"s 110"s for pulling. It doesn"t slip but it won"t "slow down/gear down" under heavy loads.
