G. Crawford Pulling CD
T.Gardner in MI
08-29-2004 16:39:41
Thanks for the pulling clips. Great shots and sounds. I still think that JD won! It looked like the transfer sled had it's brakes locked. Sure had a lot of smoke around the wheels.
Thanks again. Tom
Hot Rod
08-30-2004 12:32:00
 Re: G. Crawford Pulling CD in reply to T.Gardner in MI, 08-29-2004 16:39:41
You are exactly corret Mr.Gardner. Crawford uses the brakes to control the sled so his tractors reach the greatest distances for the high prizes.
He also puts the transmission on the sled in reverse when you are pulling. Just ask him how many drive shafts he has broken on the sled. I did and he said that was the weak link on the sled and they break a number of them every year.
Give me a break. I once had a full pull and his excuse was that they didn,t have the sled in gear. I don't understand what gear he was referring to because the weight box moved all the way forward. On the next pull the box moved forward 50% of the distance and I spun out. Then he pulled his super duper Farmall H again and it didn't even get a full pull but it pulled farther than I did. He certainly must have had the sled in reverse or the brakes on or both or I wouldn't have moved the weight box only 50% of the distance forward and then spun out.
I loaded up and left. His pulls are rigged. I don't mind losing fair and square but Crawfords pulls are anything but that.
I refuse to pull his sled again.
Taken 4 a Ride
08-30-2004 21:27:56
 Re: G. Crawford Pulling CD in reply to Hot Rod , 08-30-2004 12:32:00
I too have been a victem of the Crawford sled. Funny how my tractor could hardly get the sled off the line and could only muster about half the distance of his tractor with smoke and dust just flying off my tires. You know something is not right when some of the spectators were questioning whether the sled was still in gear while I was hooked onto it. I would be willing to pull my tractor against his on our clubs sled with me running our sled... winner keeps both tractors. Seeing as he whipped me so bad this should easily add one more tractor to his collection.
Gerry_Luzerne
08-30-2004 06:04:25
Your welcome Tom. Had a busy last couple of days. That was a great show. Have been going there for a few years. Now have the camera to share the fun. SO long..... Gerry...
