310B transmission problem
Bob Rockwood
08-29-2004 14:44:02
I have a line on an otherwise good 310B loader backhoe, but the shuttle hesitates going from neutral to forward and/or reverse. The problem is worse the higher the gear selected. Does this sound like something minor like changing oil and filters (haven't been done in quite awhile) or is it a common and major issue with the 310?
Thanks for any input.
Jonathan in MA
08-30-2004 15:06:34
 Re: 310B transmission problem in reply to Bob Rockwood, 08-29-2004 14:44:02
some things to check...lift the rear wheels off the ground with the stabilizers..put the shift levers into 7 or 8th speed ...clutch pedal down , throttle lever moved to high speed...reverser lever in forward..right foot FIRMLY on both brake pedals...with engine speed near max. release the clutch pedal (not too fast) ..the engine should stall within 5 to 10 seconds. Move throttle to slow and restart if it stalled. Now try the same thing in reverse...may only be able to get into 4th reverse as the machine probably has high range lockout in reverse. On a properly operating machine , the engine should stall in both directions. If it keeps running and only bogs down in both directions, its usually a pressure adjustment (cheap) ...or SOMETIMES the engine clutch is slipping, but you will smell that in a short time.. If it slips in only forward and stalls the engine in reverse, then you are looking at splitting the tractor and replacing some reverser parts...a few dollars but not too ridiculous as well as the labor to do that....If it passes the test, and is only slow shifting, that can usually be adjusted with a needle screw adjustment on the reverser control valve...but normally you dont want aggressive shifting as the front wheels will be off the ground shifting reverse to forward...
