John Deere 420 Yard Garden Tractor
Joe Koenig
08-29-2004 14:38:02
We are in need of the idler bracket that the idler pully attaches to on a horizontal tensioner.
Ours was lost in the yard and we cannot find it, and JD says they are no longer available.
Any help greatly appreciated. We could make one if we had the dimentions. Thanks and God Bless
Joe
Bob
08-31-2004 21:36:04
 Re: John Deere 420 Yard Garden Tractor in reply to Joe Koenig, 08-29-2004 14:38:02
I emailed a guy in Michigan that I have bought Deere LGT parts from in the past, and he thinks he MAY have what you need. I emailed him a scan of the parts book page showing the part, so he knows what you need.
He said he is unable to look for the part until Thursday, and I replied that if he found it I would put you guys in touch with each other.
Email me, if you still need the part.
Joe Koenig
09-06-2004 17:03:15
 Re: John Deere 420 Yard Garden Tractor in reply to Bob, 08-31-2004 21:36:04
Thanks much for your reply' I Do still need the part and will be more than happy to hear from Michigan.. I've had a busy weekend, and hope yours has been a good one to enjoy. Thanks again.
Joe
leon
08-30-2004 04:48:50
If this is a JD Lawn & Garden tractor, the 420 is of fairly recent vintage and I have trouble believing that the part is no longer available. How about checking the JD Parts web site to see if your JD Parts counter guy is giving you the straight skinny. If you'd give a more detailed description of the part, exactly where it's uded and the serial number range of your tracor I'd be glad to look it up for you and find out about part availability in case you can't get the Parts web site to work for you.
Joe Koenig
08-30-2004 17:33:32
 Re: John Deere 420 Yard Garden Tractor in reply to leon, 08-30-2004 04:48:50
Thanks loads for your help~!!1 The tractor serial # isM00 420X286245. The part number for the idler bracket is--AM39257. If you can help it will be greatly appreciated. This is the ldler for the front PTO Belts. Thanks bunches, I WILL WATCH FOR YOUR REPLY.
Yours Joe Koenig
leon
08-31-2004 05:12:41
 Re: John Deere 420 Yard Garden Tractor in reply to Joe Koenig, 08-30-2004 17:33:32
My apologies to your JD parts guy. Apparently he's telling it like it is. The part mumber AM39257 is shown in the parts book for a 420 and indeed was a good part mumber, but is now "invalid", which means no longer available. It seems to be a clevis made of flat stock, welded to the end of a short shaft to form sort of a "Y" shape. The shaft then has a snap ring groove in the end opposite the clevis. If you could find the part, or even take the parts to which it mates up to a weld shop, I'm sure they could make you another. Perhaps you could make it yourself by substituting threads and a lock nut for the weld and threads and a nut for the snap ring that goes into the groove. Maybe you could borrow the pat from another 420 to use as a pattern to make a new one. Good luck.
Joe Koenig
08-31-2004 14:32:43
 Re: John Deere 420 Yard Garden Tractor in reply to leon, 08-31-2004 05:12:41
Hi Leon
I want to thank you for your help and interest. I think you go beyond the call of duty!!!
I will try to find someone with a 420 to have a look. I found a 430, but it is altogether different than mine.You explain the part acurately. With mine being lost I'm sort of out of luck as for diameter and length. I have an idea though, to get belts that fit tight and forget the idler, what do you think? Thanks a bunch, I appreciate your help. Yours Joe
leon
09-01-2004 04:39:54
 Re: John Deere 420 Yard Garden Tractor in reply to Joe Koenig, 08-31-2004 14:32:43
I doubt that you' will have much luck with trying to get and install exact size belts and get by without the idler. Perhaps I'm wrong, but belts do stretch!
Joe Koenig`
09-01-2004 15:48:37
 Re: John Deere 420 Yard Garden Tractor in reply to leon, 09-01-2004 04:39:54
I am not at all convinced,and would try only as a last resort. Thanks for your interest, and have a great day!!!
Joe
