70 D end play increasing
Dan in Ohio
08-29-2004 12:16:32
About one month ago I put in the new spacer, thrust plate, shimms, thrust washers, and set end play to 0.007- 0.009. Now I have 0.020 end play but no unusual noise. What should I do, I want to correct this before it gets worse.
Clooney
08-30-2004 06:02:44
 Re: 70 D end play increasing in reply to Dan in Ohio, 08-29-2004 12:16:32
Dan, Frank pretty well covered the re-setting.. I will just add that you might want to first see if the flywheel has migrated back off the crankshaft a little.. Try loosening the pinch bolts & tightening the large tin nut while hitting the flywheel with a lead hammer, or block of wood & regular hammer, it might be as simple as a flywheel that has move out slightly.. If that�s the case trash the original pinch bolts & use grade 8 standard bolts with hard nuts & hard washers.. That tin nut is a good position keeper but will allow some flywheel movement if it really wants to move.
[email protected]
F-I-T
08-29-2004 17:27:30
Dan:
Some of that new play could be from the thrust washers "wearing in". If there were any scuffs, or burrs that have now polished off, it would not be abnormal for it to now exceed your initial setting. Personally, at .020", I would not be too worried. I would watch it, though.
If you do want to re-set it, of course you would have to remove the flywheel after blocking the crank to the left to keep the inner thrust washer from falling out. Then you would remove approximately .012" of the existing shim so that the thrust cover could move in and close the clearance between the thrust washers which sandwhich the thrust plate.
One of the neatest tools I made for my 70D project was a piece of tube steel cut to the thickness of the flywheel so that I could set and check the thrust without reinstalling the flywheel. Really saves your back!
Frank-in-Tallahassee
70D // 855 // VAC // IHC �Cub�
[email protected]
