Float Ride Tortion Springs
Soldier Tom
08-29-2004 07:10:06
I can't get the boogers to come off. The rest of the seat is in pieces, but can't make the springs turn loose. Cussing them don't help either. I KNOW somebody will have a secret for making them let go of the bulkhead. I don't want to break nothing I don't need to, I've aready broken a couple of the flanged bearings,oops.
Thanks,
~Walk in peace~
Soldier Tom
ia dean
08-29-2004 18:53:18
 Re: Float Ride Tortion Springs in reply to Soldier Tom, 08-29-2004 07:10:06
A re-build tip.Cut a 2 foot piece of 1/2" pipe. Set it on an anvil and hit the end with the old cross peen enough to put a lip on it.Insert that end between the spring ears and pry down. This will spread the ears enough too start the adjuster rod without slipping out.
Soldier Tom
08-30-2004 18:34:22
 Re: Float Ride Tortion Springs in reply to ia dean, 08-29-2004 18:53:18
Thank you much, I will try that for sure! I wonder if all them little bearings are still around somewhere, or could a body maybe find them laying around a tractor supply store somewhere?
~Walk in peace~
Soldier Tom
Dan in ohio
08-29-2004 10:59:39
Soldier Tom,
I used an air chissel/hammer when I rebuilt my float ride seat to get it apart. Getting those rubber torsion springs off is the hardest part. I also used a flat bar/nail puller left over from my carpenter days. There is nothing but rust and friction holding them on once you get the tensioning bolt off. Keep at it, they will come off.
Soldier Tom
08-29-2004 14:59:15
 Re: Float Ride Tortion Springs in reply to Dan in ohio, 08-29-2004 10:59:39
GOT IT! Ground off the "nipples" flush, then drilled out a little more, some PB Buster, and off it came with a little persuasion from screwdrivers and hammer. Now to get it all painted up and ready to put back together. I might try FIT's electrol'sis bath.
~Walk in peace~
Soldier Tom
Soldier Tom
09-01-2004 17:27:24
 Re: Float Ride Tortion Springs in reply to Soldier Tom, 08-29-2004 14:59:15
Well, what do ya know? Nick Barbieri up in NY sells "flanged bearing and pin kit to reubild seat" for about 50 bucks. That is gonna come in handy!
~Walk in peace~
Soldier Tom
