Any one run pto implements with a JD two cyl?
Rick in central
02-04-2004 05:40:33
anyone ever run a forage harvester or any other simular implement with a two cylinder JD tractor? I was wondering if the power flow was smooth or could you here the power impolses (spelling) throgh the implement? I have never run anything with twi cyl but have herd from others that the impolses could be herd thrigh the implement which I find hard to belive. I am looking a late styled A to run a forage harvester with and am wonder how it would handle such an implement?
Doc
02-05-2004 15:40:01
 Re: Any one run pto implements with a JD two cyl? in reply to Rick in central MD, 02-04-2004 05:40:33
Hmmm.... I'll bet the other colors would tear up a driveline if lugged down too. Probably more of a factor of "abuse" rather than the "uneven" impulses of a Deere.
Then again... Some of the other colors wouldn't begin to lug like a Deere. Most 4 cylinders come down quick when they get off the peak.
Food for thought.
Dad used to pull the rope and drop his 4-16's in the ground with our 730 D just above idle. Gosh it would be good to hear that again...
Doc
G-MAN
02-05-2004 16:51:07
 Re: Re: Any one run pto implements with a JD two c in reply to Doc, 02-05-2004 15:40:01
A good-running two-cylinder going under load and then accelerating with it will give you goosebumps, won't it?
JDeereG
02-05-2004 05:16:52
We ran a cain mill with a 1935 B last fall. The mill had to be run at a low rpm, so we thought it would be nice to hear the old 2 cylinder chug while we were grinding. When we hooked to the pto, the mill shook like crazy. When we used a belt on the pulley, though, the mill ran as smooth as silk. I think the main question with running the equipment off the pto is if you are running it at 540 rpm or at an idle. The impluses are closer together at 540, so you don't notice them as bad.
Hillbilly in Vegas
02-04-2004 22:53:26
I have a 620 gas and a 730 diesel - both restored rowcrops. My brother and I use them to take up hay on our farm in Tennessee. Both can easily handle a 7 foot NH haybine and Vermeer Roller. We run them at the "rated" speed for 540 rpm PTO on the tach-hour meter. No problems so far and it always draws a crowd farming with older tractors.
720Deere
02-04-2004 19:38:38
The main contributer to driveline failure that I have seen with the first numbered series thru the 530-730 is not lining the drawbar up with the pto shaft. The drawbar must be moved off center to line up with the pto and most people never had enough gumption to move it back an forth. This angle coupled with over lugging the tractor to near idle speed can kill just about any pto shaft. I would not necessarily call this a design flaw as no tractor manufacturer ever rated their machines to run that far below pto speed.
It's just like the guys that try to kill a tractor on the dyno and then brag about the hp it made. My 720 diesel is rated 540 pto rpm at 1145 engine rpm and I would never dream of running a pto load below 1000 engine rpm. If you try to wring every last ounce out of them, you eventually will and something has got to give.
Loren
02-05-2004 03:39:31
 Re: Re: Any one run pto implements with a JD two c in reply to 720Deere, 02-04-2004 19:38:38
I would like to disagree with this logic. If what you are saying is true, it would also be necessary to always run the implement level with the PTO shaft. Or are you saying that an angle to the left or right is a whole lot worse than an angle that goes down or up? Isn't an angle and angle? I can't see how the direction of the angle would be a factor and I can't imagine anyone suggesting that the shaft would have to stay straight with the PTO drive.
Tomcat in Ky
02-08-2004 12:17:17
 Re: Re: Re: Any one run pto implements with a JD t in reply to Loren, 02-05-2004 03:39:31
Yes an angle is an angle But the greater the angle the more the bind is on the universal joints. By compounding the angle up and down with left to right you increase the angle and the bind on the universal joints. The result- more vibration or impulse to tractor and implement.
John
02-05-2004 08:08:51
Loren you are correct. An angle is an angle. In a perfect world the PTO run run at a 5-10 degree angle left and right and up and down with the angles being equal in all directions. This would give the least vibration and strain on the u-joints. For u-joints to work properly they CANNOT be in a straight line and there HAS to be a slip yoke. The driveline changes length 2 times per revolution as the u-joints swing through the angles. The more sevear the angle, the more deflection in lenght of the shaft as well as the more stress on the joints. I don't remember the formula off the top of my head but the HP rating of a U-joint driveline decreases as angle increases. Seems like somewhere around 20 degrees the HP level is about half of what it is at 5 degrees. Another $.02 worth on a simple question.
Deere will work OK on PTO, just keep it at 540 to help smooth out the pulses and dont try to run it right at rated HP on the PTO. Use a bigger tractor than needed and it will be smoother.
Tomcat in Ky
02-08-2004 12:22:24
 Re: Re: Re: Re: Any one run pto implements with a in reply to John, 02-05-2004 08:08:51
I didn't read Johns follow up first but we're both on the same page
Jake
02-04-2004 16:45:08
My dad tried a new snowblower years ago on the back of a JD 420 tractor. It kept breaking shear pins. When the same blower was put on a higher horsepower tractor (with in the rating of the snow blower) of more cylinders the shear pins did not break.
farmerbill
02-04-2004 15:34:06
I just love this argument. Two cylinder tractors have the reputation of tearing up pto drivelines. I have never seen this be a problem! Have ran everything with them sickle mower, auger wagon, grain auger, corn picker, corn sheller, pull type combine, even a forage harvestor and have never once noticed any uneven operation. I have pulled the guts out of a 70 diesel on a #12 forage chopper and it will never feel any different than with anything else. I have put them on the dyno and pulled them down far below rated speed, like idle speed or less, and at that speed you will get pretty uneven operation. Doing that to a implement would no doubt shorten the life of the driveline. I have always maintained that the driveline problems were the operation of machine and not the design of the tractors. If what people say were true no one would have bought two cylinder tractors. We have had deeres since 1952 and have never once blamed a problem on the two cylinder design. As far as running a chopper with a "A" I hope it has creeper and you are not going to chop to fine! The chopping I do doesnt amount to much, basically a reason to play with the tractor and chopper but in good corn with over thirty thousand population it is a good load for a 720 diesel. It does turn some heads when somebody sees you out chopping and it is always good to hear one of those diesels working.
MK
02-04-2004 18:51:51
 Re: Re: Any one run pto implements with a JD two c in reply to farmerbill, 02-04-2004 15:34:06
Just to be clear on what I said and agree with farmerbill, we never had any driveline problems running 2cyl's but lugging them down to almost idle speed no doubt is gonna cause trouble. Otherwise, I believe they are as smooth as a 4/6 cyl.
MK
02-04-2004 15:20:30
20yrs ago we still used 2cyl's for most of our farming operation. My dad had a D,60,630,830 and I had a 630 and 730. They turned a NH 495 haybine, NH 268/JD337 sq baler, manure spreaders etc. My dad had a JD 34 or 38(can't recall forsure) forage cutter and a JD 96 combine on the 830. All worked fine if you didn't lug them down.
buckeye al
02-04-2004 15:19:50
25 years ago a guy I know ran a then old Fox chopper for years with a Ford 5000. One day the 5000 died so he looked around for what to pull it with next. Only real choices were an old M and a late 820 that was new to him. He'd only had it a few months & never really did much with it as he was really not very familiar with any JD equipment let alone the 820. He was surprised at how well the 820 ran the chopper. He was a Ford man anyway & thought he'd have to crawl with the 820. It did MUCH better than he expected so as was his nature, he ran it hard as he could. After about 10 hours, all #$%^ broke loose! The chopper had a right angle gear case at the rear end of the drive shaft. That gear case burst into pieces. His Dad owned an implement dealership & there were 2 more old choppers just like it out "in the back row" so off he went to get another gear case. That one only lasted about 6 hours! When he came back for the next gear case, the head mechanic asked just what in blue blazes he was running that old chopper with, a 7000? Nope, an 820. Good Lord no wonder he exclaimed! Get that 820 off of there. It has the guts to do the work but the chopper's only flywheel was the belt driven blower wheel & the drive line of the chopper simply couldn't take the pounding. Was like being driven by an impact wrench. The 820 is still going. The chopper was scrapped after a few more years but it was never run by the 820 again!
I have an IH 45T baler. A jerky beast to start with but when I run it with a '51 B you better be on your toes on the wagon or you'll soon not be there! It does not seem to like the 70D much better but the early styled A's seem to run it rather nicely at around 2/3 throttle.
Over all I'd say probably the best answer to the question "how might it handle the equipment" is.... that all depends!
Later.
Ralph - WI
02-04-2004 20:14:25
 Re: Re: Any one run pto implements with a JD two c in reply to buckeye al, 02-04-2004 15:19:50
You said what I was going to say. If I remember correctly from 50 years ago, that 45T had no flywheel but a heavy plunger. A NH 76 stressed the neighbors drawbar on his JD A but wouldn't break it. I have seen drawbars shaken loose and then ripped up by those 45T's. They were also useful at making oval holes out of round ones on the hammer straps of wagons.
buckeye al
02-05-2004 16:24:18
 Re: Re: Re: Any one run pto implements with a JD t in reply to Ralph - WI, 02-04-2004 20:14:25
The 45T had a flywheel but it was inside the front of the bale chamber. Because it had such a small diameter it wasn't nearly as effective as the large diameter heavy rimed ones most everybody else used! Hook up an old wandering wagon with loose bolts at every pivot point in the tongue & it was a real adventure. Unfortunatley I have never run it with an IH H or M.
Should have heard what it would do to the 70D's live PTO drive train when the front gear case shaft bearing (right behind the flywheel) was loose. Hammering noises came from everywhere when you turned a corner. Didn't have to bee a sharp corner either! Best to just turn it off! Nice & quiet with a new bearing but it's sill a jerky baler. Brother's 24T bales ring 'round it too.
DON
02-04-2004 19:35:54
That old 820 simply had more power than the chopper had gear box. It was probably whopping out 90 hp and the gear box simply couldnt take it. we had an 830 that would outpull a 930 case in gumbo with a chisel plow. no contest.
buckeye al
02-05-2004 16:25:43
 Re: Re: Re: Any one run pto implements with a JD t in reply to DON, 02-04-2004 19:35:54
It sure surprised him. Gave it a nickname..... King Putt.
Later.
Deereman
02-04-2004 13:55:25
I use a bushog behind my A, it is just as smooth as a 4 or 6 cylinder.
MIKE HANLEY
02-04-2004 11:24:18
Additioal thoughts. The shaft size and the 540RPM's had national standards. But there were no national standards on where the PTO was located,,,,, how high off the drawbar the PTO is located. The hole in the drawbar should be 14" from the end of the PTO shaft. The old JD equipment had ajustments at the first bearing on the tougne to ajust the PTO shaft up or down so that the PTO line had a little angle as possible at the joints. A bad ajustment here could cause PTO problems. Then add a sharp turn to that set up and it's that much harder on the joints. Newer equipment now has a piviot point between the end of the tounge and the drawbar. That tells me there was still a problem with PTO's long after 4 and 6 replaced 2 under the hood.
buickanddeere
02-04-2004 10:55:19
The original pto shaft on the 14T baler was replaced with a HD unit from a 540 rpm forage harvester of that era. The 70D would pound the u-joint bearings out after 500 acres of custom baling. The fast tractor gearing, double windrows, oversize shear pin bolt and young guys on the wagon competing may have contributed. When running the antique collection on the pto generator for exercise. The 70 gas in particular can find resonant frequencies at a couple of part load levels. The others are fine unless being lugged below rated rpm. The faster diesels,50 and gas 20/30 series do operate smoother than the 975 rpm 60 & 70 gas. The two stroke 2-53 powered 435 with twice as many impulses at 1/2 the intensity runs butter smooth. The 40 does pretty good as well. Have to watch the electrical loads however or she will drop below 60 cycles.
Bob
02-04-2004 10:29:54
I used to run a Matthews 800 grain dryer with a 730 diesel. I busted the countershaft on the dryer twice, where the last 4" of the shaft is turned down to fit inside the PTO knuckle, and connects up with the drive flange with a shear pin. The dryer was a pretty good load for the 730, and you could feel the power pulses.
Later, I run the dryer with a 4020, which "played" with the load. I never had driveline problems when using the 4020.
I think there is definitely some truth to the story that the old 'poppers are tougher on PTO equipment than 4 or 6 cylinder tractors. However, for lesser loads they do just fine.
JD Know it all
02-04-2004 09:43:59
When discussing these sorts of things one must also consider the size the JD engine compared with the size of the engine on other brands, the 820/830 for exmaple had 471ci which is big engine even by todays standards, IF JDs are hard on PTO equipment, I think it would have more to do with the size of the engine rather than the design, I will give an example of this.. the engine used in the farmall M had 264ci? were as the engine used in the JD A had 302ci?
GPWT
02-04-2004 09:30:49
I have been running a heavy duty 90" finish mower with a JD 730 diesel for 10 years now without a problem. I often use this as a brush hog so it's loaded down, not just loafing along.
John
02-04-2004 09:27:10
My experience with the 2cyls and PTO is they work well with stuff that was intended to be run on them. Most of the old stuff had some flywheel or momentum built into them to help smooth the pulses. Newer stuff relies more on the HP of the tractor and the driveline. Sometimes the newer baler behind the 2cyl when in a heavy windrow will get in time with the pulses of the engine and it gets pretty hard on the driveline. Has been known to bust the shear bolt. Same problem with a bush hog. Even an ant hill can be enough to kill a shear pin. Those big flywheels on the JD's are hard on sudden jolts to the pto. Hay mowers seem to work fine but sure sound funny when first spooling up. My advise, keep the RPM up. If they tractor lugs find a lower gear or a bigger tractor.
fixerupper
02-04-2004 08:45:16
Dad ran a Minneapolis two row pull type picker for fifteen years with a 51 A and he said he could see the chains jumping just a little bit, but he never had chain or pto problems. On the other hand, our neighborhood baler was a JD 24T pulled by a 60 and then a 730 and we replaced one PTO knuckle every season. After the 4030 was put on it we never replaced another knuckle.
Bernie in MA
02-04-2004 07:39:05
I've run a 15A flail chopper with my 420C for years, both chopping sudan/sorghum, grass, and brush up to 2" in diameter (alders) and smaller hardwood brush. For the brush I opened the back so it went on the ground, always using first gear. For the grasses I used second or third (out of five). I've never noticed any "pulsing" of any kind. Incidentally, pulling both steering levers back with the clutch out gives you live power on a crawler.
Stan - Florida
02-04-2004 07:31:35
To echo the comment below about PTO equipment being designed for the tractors of the day, that's very true. I would also agree with the post that said that newer, bigger choppers, etc. might be too much load for your A.
Back to the basic question...Sure we have...'1943 B ran a 1-row pull-type heavier than he!! corn picker (6 years), '49 A ran a No. 200 two-row pull-type picker (14 years), an A-C All-Crop 5' combine (13 years), a 14-T baler (8 years)and probably other things after I left home. '52 B ran the same combine and baler for probably 6 or 7 years, too. Maybe we didn't know any better, but we sure never felt any impulses except the plunger strokes on the baler.
Stan
Ravgardner
02-04-2004 07:22:01
We ran a JD Flail chopper with our 49 A. Plus the JD kicker bailer and other PTO driven equipment. As was stated previously, spin up the implement with the wheels in neutral, then shift the tranny into a forward gear. Live pto's are great, but the A can do as well if the operator understands how to run it. Do you know the horsepower requirements for the forage harvester? Is is greater than the the A? That is the information I would want. I know I could get the A to do the work if the engine is big enough.
Ron
02-04-2004 07:00:41
Probably the BEST advise would be to get a Diesel 70, 720 or 730... I know that these will handle the average forage harvester... Try the "A"...you may be well satisfied with it, but see if it will first..!!
'51 A
02-04-2004 06:53:40
Back in the days when we shared a Gehl chopper with the neighbors, the 730 on the Gehl chopper would fry the knuckles. The neighbor's D 17 would not. The pounding done by the 730 would take the knuckles out in a day or so of heavy pulling even though the knuckles were greased three times a day.
Dan
02-04-2004 06:48:54
Several years ago I ran a pto baler with a 1938 G. It worked great and probably ran the baler better than other tractors Ihave used. It of course does not have the live pto so I get the baler turning with the tractor in neutral and let it continue with the overrunning clutch while putting the tractor in gear. I think the torque on these old rigs really helps. There is a balance between the heavy stuff inside the implement and the heavy pistons up front.
Ron
02-04-2004 06:23:56
The 2-Cylinder tractors are so smooth, you won't believe it..!! The only time you have a problem is if you pull it down too far... Pulled down too far, they will "Lunge" against the PTO.. I prefer the Later Models, that have more RPM... You will probably run that "A" at full throttle, to have some RPM to work with... You won't have live PTO, so you won't want to get it pulling down...!!! At least a Late "A" has the creeper gear..!!! Make Sure it is a GAS "A"..an "All-Fuel" will not have enough power...
MIKE HANLEY
02-04-2004 06:23:48
It depends if someone answers from an office with a pen and paper and a square rule or if years of field experance is presented. Two bangers have been running PTO equipment since what the 1930's? What is hardest on a pto line is turning too short. Followed by running too high RPM's. But a "A" on a chopper well,,,,,When the "A" was new the chopper that John Deere had out was matched to the tractors of that day. AND field yields were less then half of what it is today. But a moderen chopper in todays yields you maybe lacking power. A hay head harvesting a singe windrow from a 7' mower maybe alrigth in 1st gear. A "A" may handle a JD 35 chopper, but I would question anything bigger or newer. Live PTO is so much better as if you get into a tough spot, you can stop the tractor and let the chopper clear. You can't do that with an "A". We run JD 350 mowers and a JD 510 round baler (1750# bales) and a JD 506 rotory mower and a JD 35 post hole digger with two bangers.
jdhbab
02-04-2004 05:52:38
Rick I have never pulled a forage harvester with an A but have lots of hours pulling them with a 60 and a 620. I didnt notice any difference in the power flow of the 2 cylinders from the 4 and 6 cylinders i pulled with later. I thought the 2 cylinders did a good job.
