720 LP . How long will it run?
cdm
08-28-2004 17:26:51
I bought 720 LP. This is my first experience with propane. Local LP company filled tank, and I have been mowing with pull behind 6' mower in 3rd gear. LP tank gauge does not work. I have mowed, and mowed, and mowed. How long will this thing run on a tank of LP? thanks in advance.
730-LP
08-28-2004 21:48:59
 Re: 720 LP . How long will it run? in reply to cdm, 08-28-2004 17:26:51
Pour a gallon of hot water over the tank, above the liquid level will evaporate very quick, where the liquid is will stay wet and a lot of times will frost.Love those LP"s I have 2-730"s and 2-520"S
CLW
08-28-2004 20:45:58
Hard to say how long it will run but my guess is you are about empty. Your LP dealer can make you a hose that will work off of a small LP bottle like a BBQ grill has. It hooks to a "T" just back of the strainer. You can get the tractor back to the house if you run out in the field. You can also get a larger tank like is used on a LP forklift to put fuel in the tank. Will require a different hose. Why don't you get a larger tank (100-250 gal.) to fuel out of?
CLW
David from Kansas
08-28-2004 20:23:39
cdm,
If it is like my 730 LP, it probably has a 39 gallon tank. Usually they are only filled to about 85%, or somewhere near there, I don"t remember exactly. One thing to keep in mind is that an engine burns more gallons of LP than it would gasoline or diesel, I would guess about 50% more. One way you can estimate the amount of fuel left in the tank is to feel the tank in the morning when the sun is shining on it. The liquid will cool during the night, and the tank will heat up more rapidly above the liquid line. If you had one of those temperature gun dodads you could probably tell exactly where the liquid level is. Best I can do for you. Hope it helps. I"m sure you will get lots more helpful suggestions on here.
Nameless in Tallahassee
08-28-2004 20:37:16
 Re: 720 LP . How long will it run? in reply to David from Kansas, 08-28-2004 20:23:39
If you wet your finger with spit, and wipe a line down the side of the tank, the vapor half of the tank will evaporate the spit quicker :)
Works on water tanks, too.
Frank
Bob
08-28-2004 20:20:07
Not quite long enough to get back to the yard from your last mowing project.
