4010 Gas runs ragged
ET
08-28-2004 05:12:11
We recently got a 4010 gas tractor with 1819 origonal hours on it everything is tight and nice. It's a row crop but has no rockshaft or 3pt hitch. I pulled a bushhog mower at a womans reform school all its life. My problem is at high idle the engine runs kind of ragged whith a bit of skip. When the engine comes under load it settles right down and sounds good with lots of power. It idles smooth and nice. The carburetor is a zienith wiht a fixed main jet and anti- diesil solenoid I have had it apart and cleaned and rebuilt it. I have given it a complete ignition tune up, copper core wires,and autolite plugs( equal to champion D21). I think it is overfueled untill it starts working. What do you guys think?
Gerald J.
08-28-2004 20:44:20
 Re: 4010 Gas runs ragged in reply to ET, 08-28-2004 05:12:11
Is the manifold heat on? It should be for temperatures up to 90 for light loads and for temperatures up to 70 when plowing.
I find my 4020 gas doesn't care for gasohol either, running a little rough. I can't set the manifold for heat. Its split and I'd have no muffling of the exhaust.
I think the high speed jet is adjustable, there's a little screw on the opposite end of the solenoid from its mounting. That's the mixture adjustment. Failing that you can change the mixture by lowering or raising the float level.
Gerald J.
RAR/IA
08-28-2004 12:13:44
Any black smoke when it is running ragged? That would indicate over fueling. But if you have a fixed high speed jet, you could only change it. With good power sounds like not much is wrong with it. Any black smoke when under load. With a gas their shouldn't be much if any. Not like a diesel.
Roger in Iowa
