 Rich, as you have found out that 520 has the clutch pivot bolt running from the outside towards the inside with the inside of the bolt tip about 2" from the center of the shift tower. That means there is no way to get much of anything behind that pivot bolt & push on it. ~I have had some luck using a large C clamp with a deep socket over the outer head of the pivot bolt, but you are much better off with a special steel strap type puller.. ~By far the best way is to use a puller to force that pivot bolt out.. Those serrated pivot bolts fit so tight that even penetrating oil can�t get between the bolt & housing ear to help much.. ~I made a tool to pull those reverse facing pivot bolts on the numbered series tractors & all it consists of is a couple of �� thick X 2-1/2� wide steel straps about 6� long.. The outer strap gets a large hole drilled in the center to clear the head of the pivot bolt & both inner & outer straps get smaller holes drilled to allow straight pieces of All-Thread to be inserted through the holes so when the nuts on the All-Thread rods are tightened the pivot bolt gets forced out.. ~As John said, you might try Mike Alward as he was making those pullers a while ago.. His E-Mail address was [email protected] but I'm not sure if it is still the same.. ~Excuse the rather poor drawing as I don�t have a CAD program on this lap-top computer but it should give you some idea of what you need.. The 2 rods shown are actually straight & not bent [I told you it isn�t a good drawing].. ~Be real careful while working on removing that pivot pin as those reduction cover ears break off real easily if that bolt is hammered on.. [not that you could get a hammer on that bolt anyhow due to it�s close proximity to the shift tower] .. Resist the urge to pry on it also as that can also break the reduction cover ear� [email protected]
