D question
Chris
08-27-2004 17:44:40
On my 35 D to the outside and behind the spark plug there is a small white strip that looks like a wick screwed into the clock. Any idea what this might be? Not to familiar with it yet. Thanks and have a nice day.
Marty Z
08-28-2004 17:44:58
 Re: D question in reply to Chris, 08-27-2004 17:44:40
That is where the water injector used to go and some one must have stuck some kinda plung in it"s place. My 35 D arrived with a wood stick tapered and twisted in the same hole. It will take a regular pipe plug just fine to seal it right. If you look about 8 " above the hole on the side of the carb there is probably an un - used plug in the side that used to hold the other end of the injector.
Marty Z
Chris
08-28-2004 20:44:23
 Re: D question in reply to Marty Z, 08-28-2004 17:44:58
Thanks to everybody for the info. I kind of thought that it might have been water injection but I didn't dee the water tank. I thought the old GP's had a second tank under the hood for that. Thanks again and have a nice day.
Marty Z
08-28-2004 22:28:42
 Re: D question in reply to Chris, 08-28-2004 20:44:23
The water comes right from the cooling system ,, but you can"t use anything but clear water.
My 29 GP is the same as the "D" . There is no external source for the water.
I don"t have much info for this board but you just happened to hit on two of my toys. Most of the time I just follow along and try to soak in as much as I can.
Good luck and enjoy.
Marty Z
Chris
08-29-2004 10:22:41
 Re: D question in reply to Marty Z, 08-28-2004 22:28:42
I know how you feel. I really appreciate the info though. It helped. Have an nice day.
Aberdale Farm
08-28-2004 17:34:46
Chris,
I"m not sure, but from your description of the location, it sounds like the compression relief petcocks are missing and someone has stuck a piece of rag in the hole to keep moisture out.
Dale
mike fenner
08-27-2004 21:43:02
It's probably asbestos insulation on a wire, commonly used in 'the day'.
