2640 hydraulic question
Vern
08-26-2004 20:04:51
On my 2640 when pulling a batwing mower after about a hour the hydraulics quit,no steering or lift or no remotes to raise the mower. Let it set a little while and then it will go back to working I forgot to say that the pto keeps working and it is hydraulic driven. The tractor does not have the high low or the reverser. Can someone tell me where to start diagnosing the problem? Thanks
Dieselrider
08-27-2004 04:58:21
 Re: 2640 hydraulic question in reply to Vern, 08-26-2004 20:04:51
Do you have the manuals? First thing to check would be the hydraulic screen underneath. You'll have to drain the hydraulics and clean the screen. If you find alot of brake lining on it you should consider putting new linings on the brakes too. These are subject to break down if the system gets moisture inside.
