Help! Generator test question
Ghostrider
08-26-2004 19:08:10
I finally got back to working on the Model B. After installing a new battery and voltage regulator, I still didn't get a charge. I thought I would try the motor test. After disconnecting the belt, I connected the armature post to battery power. The housing was grounded to tractor and both wires were off of the generator. When the Arm post was connected to power, the unit would turn over very slow. The jumper wire would also get hot. Then when the field post was grounded, the unit turned much faster. This is the opposite of whatis suppose to happen, right? The generator is a rebuilt unit bought from a parts store. Could the post not be labeled right?
Chris
08-27-2004 17:39:12
 Re: Help! Generator test question in reply to Ghostrider, 08-26-2004 19:08:10
Did you polorize the generator after you put it back on. I have forgot to before and it didn't charge right.
