2940 steering cylinder leaking
chris
08-26-2004 18:44:06
i have a 2940 with t he two cylinders on the front for the steering the left side is leaking bad can you rebuild thoose cylinders if so is it hard to do alos doeas anyone no if they make them aftermarket or does any other tractor have the same one on it thanks for any help
WTW
08-27-2004 09:13:28
 Re: 2940 steering cylinder leaking in reply to chris, 08-26-2004 18:44:06
If your 2940 is a two wheel drive and has two steering cylinders these cylinders are single acting (one hydraulic hose) and are rebuildable. They are very easy to rebuild as they are a displacement type cylinder which means the cylinder rod is the piston and the only seals there is to replace is the wiper seal and one packing, both located at the end of the cylinder barrel where it is leaking. To replace these two seals remove cylinder from tractor, remove steering hydraulic hose from barrel of cylinder, completely collapse cylinder removing oil from inside of cylinder, look through the hose fitting bore of cylinder barrel, at the end of cylinder rod you will see a round wire snap ring setting beside a groove on the end of cylinder rod. With a small screw driver working through hose fitting bore pry snap-ring from high grove it is setting on into the lower grove of cylinder rod, remove rod from barrel with the snap-ring in the lower groove, Once the rod is removed from barrel simply replace the two seals at end of barrel (one wiper one packing) install rod with snap-ring in lower grove through new seals, align snap-ring groove up with hydraulic port hole and pry snap-ring back up on tall groove. Simple as that. Good Luck Dave W.
