4620 John Deere questions
Chris
08-26-2004 16:33:09
Hello,
Is there a way to turn the 1000 pto on a JD4620 to 540? Did any of these come with dual pto speeds? Aso what might the value be on the 4620 with cab, duals, good rubber, 3pt new paint, low hours on overhaul. Just looking for a general price range these might go for. Thanks a bunch,
Chris
JDBert
08-27-2004 06:51:10
 Re: 4620 John Deere questions in reply to Chris, 08-26-2004 16:33:09
You can go with a stub shaft 1000 to 540 usually cost about $50-100. All these really do is convert the 1000 splines to 540 splines but no speed change!! Usually if we do this on ours we just keep the RPM's low and run it. Price range as always depends on the condition but from what you've said (if its not all beat up) I say around $7500-9000 would be about right. There a good ole horse, indestructable rearend and most turn around 150+ horse.
Bob
08-26-2004 17:49:34
There is a way, it"s aftermarket, though, and not cheap, unless you can find a used unit.
msb
08-26-2004 17:06:39
The answers are no and no.1000 RPM only and no way to convert it to 540 that I know of.
