JD 1520 IPTO or 2 stage clutch ?
km07
08-26-2004 08:41:40
Looking to but a small utility tractor and wondering which ones have an independant pto not a 2 stage clutch. Called about a 1520 sounds like it was a 2 stage? Did they come both ways?
I Bleed Green
08-26-2004 13:45:23
 Re: JD 1520 IPTO or 2 stage clutch ? in reply to km07, 08-26-2004 08:41:40
A 1520 can have any of the 3. Independent, Continuous running, (I has the 2 stage clutch.) And Transmission driven PTO. If the tractor has Independent PTO it will have a lever between the transmission shift levers. It will also have a lever on the left side of the transmission. (2) levers if the tractor has mid PTO. Tractors with Independent or Continuous running, can be single 540 rpm, or dual 540-1000 rpm. Tractors with transmission have single 540 rpm PTO only.
ags
08-26-2004 14:24:34
 Re: JD 1520 IPTO or 2 stage clutch ? in reply to I Bleed Green, 08-26-2004 13:45:23
My 1020 has a rear and mid pto. How do I determine if the rear is a 540/1000? Is there any way to determine this without a 1000 rpm stub shaft?
I Bleed Green
08-26-2004 19:51:25
 Re: JD 1520 IPTO or 2 stage clutch ? in reply to ags, 08-26-2004 14:24:34
If a 1020 is like a 1520, this i how you can tell. Tractors (without independent PTO) have 4 bolts holding the stub shaft on. On tractors (with inderendent PTO) have a snap ring holding the stub shaft on. If you do not see bolts or a snap ring your tractor does not have dual 540/1000 rpm PTO.
I hope this helps
WTW
08-26-2004 09:11:32
Yes, Could be either way. Independent was an option but is what you really want it if you value convenience. DW
