39 A head torque
Jarrod
08-25-2004 19:47:25
Puting on a different head because my original had rusted through the coolant passage. Bad deal and very disappointing!!! Anyhow, The IT manual isn't old enough to cover this thing so I was wondering what the head torque was? Although the book isn't correct for this year, It says to torque the bolts to I believe 125 ft lbs. (I don't have the manual in front of me at this moment) Then it goes on to say torque all hardend studs (dark color) to 150 ft lbs. Well there are 3 studs that are shiny between the cylinders and the rest are dark. So finally my question is this....Should I torque it like the book says, even though it is too new for this tractor or do I torque them all to 150 and be done with it. Like I said I am not sure the exact amount that the book says because it is not in front of me now.
Gomer
08-26-2004 20:41:55
 Re: 39 A head torque in reply to Jarrod, 08-25-2004 19:47:25
125 FP is usually enough. Thats what the book says. It means that if you have black heat treated studs, you can move it up to 150 FP. I just use 125 on both my "A's".
