B runs good then starts to miss
confused Adam
08-25-2004 15:55:47
My B will run good then all of a sudden it will start to miss and back fire. its a 1946 with a wico dist. I put in rotor, coil, plugs, wires, points, cap, condenser. It seems to start missing when it gets warm. but it might just be a short. Please help! this thing is driving me nuts. Every time I think its fixed it starts to mis.
Karl
08-26-2004 09:49:15
 Re: B runs good then starts to miss in reply to confused Adam, 08-25-2004 15:55:47
I had a simuler problem with my B. When it would heat up it would start missing. I don"t know if you have muddobbers in your area but the air precleaner that sticks above your hood is a perfect building sight. When you run the tractor they break loose and clog the orfice at the bottom. Needs air to run. Happend to me.
Mike M
08-26-2004 08:11:18
Do you have a Wico mag. you could pull off another tractor and try on this one ? This would be the fastest and sure fire way to pinpoint if it was in that dist. or not.
I have heard tales from an old JD mech. that those Wico Dist. were trouble when new. Something about too much spark and sometimes at night they would make the spark plug wire tube glow from spark jumping through it. Fact/ Fiction I don't know as I never witnessed it. But this fellow was known for knowing his stuff.
Clooney
08-26-2004 04:19:08
Adam, you didn"t say how long it runs before starting to act up but first we have to determine if it�s is a fuel or spark problem..
I guess the easiest place to start is to pull the choke partially to mostly back on when the problem occurs & see if that makes any difference..
If pulling the choke back on helps you are probably fighting a fuel [fuel flow] problem..
So, first-- look at the fuel filler cap to make sure it�s vented & the vent is open [OR, try running with the cap removed to see if that helps]..
Next�open the drain cock on the bottom of the carb & make sure you have a pencil sized stream of fuel flowing out for AT LEAST 30 seconds.. If you don�t have a good fuel flow for 30 seconds or more suspect a fuel blockage [probably at the fuel strainer, or carb strainer screen at the fuel line entrance area, or at the tank exit fitting..
If pulling the choke back on doesn�t help you probably have an ignition problem or tight valve problem..
On the [possible] valve problem? That�s a simple look see & check of the valve lash..
On the ignition problem that�s a little more difficult.. You can use a timing light on plug wires to verify a spark but that won�t tell you if it�s a decent spark & probably would require carrying a 2nd 12 volt battery to power the T-Light if you need to drive the tractor to get it to act up..
What I have found works good to watch for an intermittent spark problem is to take an old spark plug wire [or even two],, then cut the plug wire about 2� from the plug ends, then strip the rubber insulation back about �� on the wire ends,, then get some clear plastic tubing with an ID about wire OD size,, then push the cut plug wire ends into that plastic tubing until the exposed wire ends are about �"-3/16� apart.. Then install the above wire [or wires if you build two] between the distributor & spark plug(s).. Then drive the tractor in a dark area or at night.. That way you can watch the spark as it happens.. If the spark turns yellow or goes away when your miss occurs you know for sure you have a spark problem.. If you have a blue spark even when the problem is happening you probably don�t have an ignition problem.
If you do have an ignition problem..
*Make sure your Wico XB distributor has a functioning resistor under that little square cover screwed to the distributor�s side.. [if no resistor that coil could be overheating]
*If your B is converted to 12 volts make sure you have another resistor in the wire between the ign switch & the distributor [that Wico XB takes 2 resistors on a 12 volt installation]..
*Make sure your spark plug wires are solid metal core & NOT automotive carbon core resistor wires..
*Make sure the Wico�s condenser is screwed down tight.. It has a condenser you just can easily see it as it�s mounted on end under the points breaker plate..
**If you find it has a spark problem & none of the above helps just post back & we�ll get you into that Wico XB farther..
Other things to check out----
-Make sure the carb has the correct base gasket & it�s not leaking due to a warped carb base flange..
-Give the engine oil a good sniff [or change it].. If your carb has been allowing fuel to leak into the engine after shut down the oil could be full of fuel & once it warms up that fuel could be working out past the piston rings & valve guides causing a cylinder richness problem.
-First & foremost.. Try a NEW set of spark plugs,, partially fouled spark plugs are the number one cause of misfire problems on the old Deere�s..
## If you can tell us how long the engine has to run before the misfire problem starts,, at what engine speeds the problem occurs at,, when the problem started & if it just occurred at full intensity or gradually has gotten worse,, & any other helpful information we can probably get you closer to the problems root cause..
[email protected]
