Building motor in a model 50 JD for pulling. Email
Daniel
08-25-2004 13:22:32
I am wanting to build the motor in my 50 for pulling. Can anyone tell me a good oversized piston that can be used in this application and how much over size can I go, and can the sleeves be removed for bigger pistons? Clooney, if you read this, I emailed you a couple questions on this subject.
John Van Valkenburgh
08-25-2004 21:11:39
 Re: Building motor in a model 50 JD for pulling. E in reply to Daniel, 08-25-2004 13:22:32
Daniel,
I'm not planning on using my 50 for pulling but I'm thinking that this winter I'll pull and rebuild the head since my valves are pretty noisy. If I do that I'll likely do the cylinders at the same time. I'd be interested in knowing what people recommend to beef up the engine a bit.
I've heard of people using power blocks in the 50 but I think they are getting kinda scarce. I'd be more inclined to simply bore the cylinders a bit.
Best of luck,
John
1953 model 50
buickanddeere
08-26-2004 19:25:40
 Re: Building motor in a model 50 JD for pulling. E in reply to John Van Valkenburgh, 08-25-2004 21:11:39
Maybe better off with a 520/530 as they are a factory souped up 50. On most tracks in reasoanbly stock classes the secret to winning is not wheel speed from HP. It"s hooking up the power she"s got in low gear and putting it to the ground. Spend you time reverse sharpening some 45 degree tires for loose tracks or 23 degree tires for hard tracks. Set the drawbar height for max legal and adjust ballast placement, drawbar length and tire pressure. Should have fairly flat spin out hole bottoms in the track and front wheels a couple of inches off the ground.
Mike M
08-25-2004 15:31:13
Don't get me wrong I am a 2 cyl. fan through and through,but that model 50 is built so heavy your done before you even get started. Someone with an Oliver 77 which is lighter to begin with can easily drop in an engine from a larger Oliver and be 100 hp before doing any fancy work on it. I'll take a 2 cyl. for real pulling--in the field--- but for these tractor races/pulls Oliver cockshutt minni mo are tough.
