1953 jd model 50
homer
08-25-2004 11:08:00
Bought a rough looking 1953 jd 50. want to restore and do a good job.was going to overhaul engine and head.Runs fine idle is fine after carb repair.pulls good.compression is 105 lb exactly same both cylinders.maybe should let engine alone???
John Van Valkenburgh
08-25-2004 18:16:53
 Re: 1953 jd model 50 in reply to homer, 08-25-2004 11:08:00
Homer,
If the 50 is a little rough, you've got lots of other things to spend your money on besides the engine. The compression sounds okay to me. If she is showing good oil pressure and there are no other danger signs such as smoking (especially after idling hot for several minutes) and there are no noises then I'd concentrate on other things first.
Listen for valve train noises. You will want to remove the valve cover anyway to check the valve settings (use a new valve cover gasket). Look for wear on the rockers etc. On my 50 the engine is in pretty good shape but the valve train is making noise and is worn out. I suspect that someone before me has rebuilt the engine at some time and probably left the head alone.
I've spent a lot of time fixing leaks on my 50. Just seals and gaskets mostly although I did have to pull the rockshaft housing and reseal the Powr-Trol system. In this case you want to look for a Powr-Trol that does not hold the lift arms up under a load, or a Powr-Trol that leaks oil into the transmission.
My 50 had the old thermostat operated shutter arrangement. The shutters were missing. The later models had a traditional automotive type thermostat inline with the coolant return line that worked a lot better.
The 50 is a great little tractor. Drop me a reply if I can answer any questions.
John
1953 Model 50
homer
08-25-2004 20:04:40
 Re: 1953 jd model 50 in reply to John Van Valkenburgh, 08-25-2004 18:16:53
Thanks John and SB for the help.I was just surprised at the compression after 50 years.I will check under the valve cover.Sure would be good to not deal w/engine rebuild expense rigt now.Does seem like there are old two cylinders around-even older B`S AND A`S-that have origonal engines.How many lbs compression is considered good.Thanks again for the reply. Homer. Ido have shutters.
08-25-2004 21:06:07
 Re: 1953 jd model 50 in reply to homer, 08-25-2004 20:04:40
Homer,
I don't know much about my tractor's history except that the guy I bought it from had gotten it from MI or MN. He painted the tractor, replaced the radiator hoses and battery but no major repairs. I'm betting that the engine has been rebuilt or re-ringed at least once, but I also suspect that the head was not rebuilt. I've got a lot of valve noise, the rocker arm bushings are worn out, and I get a good puff of smoke if it has idled hot for a few minutes. I suspect that oil is getting into the cylinders via the valves in this case.
I've got about 110 psi per cylinder. I don't know what the spec is but I seem to recall that 110 is about right. Not a lot of blow by in my engine as far as I can tell. Remember that there is a fan that blows engine gases out the vent pipe and that it's normal to have some condensation in a cold engine that will heat up and vent as the engine warms.
So you've got shutters? So does mine. Make sure to lube the shutters and assoicated linkages well. They are prone to sticking. My shutter linkage was missing and so I control them manually with a lever. It takes my 50 about 10-15 minutes to build up to 200 degrees even in the summer when the shutters are closed. When the shutters are open it rarely goes above 170. Idealy I'd have the thing set up to just open the shutters part way to keep the engine temp up between 190 and 200, but that project will have to wait until this winter.
Do you have a parts book and service manual? I've gotten a lot of use out of both.
I think the next project on my 50 will be the clutch. It's been adjusted but won't snap in and out smoothly. I'm probably going to have to put in new toggles etc.
Drop me an email if you have any questions and I'll try and answer them.
John
1953 model 50
homer
08-26-2004 04:58:50
 Re: 1953 jd model 50 in reply to John Van Valkenburgh, 08-25-2004 21:06:07
Got to get a book just have`nt got that far.Would have paid for it`s self if I had .I fixed my clutch up but broke the drive disk pulling it off.Almost imposible to find that disk and expensive too.Bad feeling and not necessary. Hope you don`t have ahard time finding parts for the head .Seems like not alot of junk yard 50s.I have never overhauled a engine by just replacing the rings.Wonder if that works ok .Always put in new pistons.Maybe a guy does`nt always need to spend that much ?Don`t know.
08-27-2004 01:59:17
 Re: 1953 jd model 50 in reply to homer, 08-26-2004 04:58:50
Homer,
I'd be inclined to replace the pistons if I were overhauling as well. As far are simply putting in new rings, you still have to use a cylinder hone to break the glaze on the cylinder walls. If you don't the rings won't set and you will have an oil burning problems.
Rebuilding the head should not be too bad. I'm guessing that there are replaceable bushings in the rocker arms. If the face on the rocker arms are badly worn they can be welded up and reground. The same is true for the rocker arm shaft, except that you need a lathe to turn it back down after welding on new material.
I can still find valves. The seats may be worn but I may be able to find replacement seats.
I'll have to check the condition of the push-rods and the lifters too.
Not looking forward to doing my clutch. I've heard that the drive disk is easy to break and is often hard to pull. Just have to take your time I guess.
Best of luck with your 50,
John
1953 Model 50
SB in AR
08-25-2004 14:17:46
No Smoke.
No Drips.
No Noises.
No Probelms.
No Tear Apart!
