1938 JD Model L question...........
Sam1791
08-25-2004 11:01:05
I have a 1938 John Deere Model L with the Hercules Engine. It used to belong to my Dad and he gave it to me. The last time it was running, about two years ago, it just stopped running like it was turned off. It didn�t make any noises just shut off and when we tried to restart it had no compression (it�s hand crank and it cranks freely). I have talked to some people in my area and have been told that it is probably the valves stuck, and it is a common problem with flat head engines if they are not ran on an at least a somewhat regular basis. Does this sound right? Or might it be something else? I�m new to the antique tractor crowd, and any input would be greatly appreciated. Also I need to locate a gasket kit for the engine before I can tear into it.
Deeredale
08-29-2004 19:58:45
 Re: 1938 JD Model L question........... in reply to Sam1791, 08-25-2004 11:01:05
We have the new gasket set for the engine. Call Steve @ 513-988-0390 for info.
Al
08-25-2004 17:58:42
Sounds very much like stuck valves. If it has set for 2 years the oil has all drained off the rings so you won't have much compression anyway. You could start by removing the plugs and putting oil in the top, crank it with the plugs out and see if you can feel any compression pushing out the plug holes. If not, the next thing to do is remove the side cover and watch the valves as you crank it over. Good luck.
Sam1791
08-26-2004 06:13:23
 Re: 1938 JD Model L question........... in reply to Al, 08-25-2004 17:58:42
Thank you very much for the reply.
