1987 JD 160 won't start
MJ71172
08-24-2004 18:16:57
We bought this lawn mower used/ The guy who sold it to us said it occasionally would have problems starting. We changed the spark plug, air filter and battery. It worked fine for a while, now it won"t start. My hubby took the starter to someone and he said it was in great condition. The battery light is very dim when you try to start it and it won"t crank. He re-wired the ignition, changed the fuse, checked all the safety features and nothing. He thinks it might be an electrical problem, I was told to check the points, we have yet to check either. Any suggestions or other thoughts of what it could be? Any ideas would help. We"ll try anything.
johndeereman
08-24-2004 20:35:27
 Re: 1987 JD 160 won't start in reply to MJ71172, 08-24-2004 18:16:57
i would try jumpering the starter out see if it starts that way sometimes the starter will stay engaged try turning the motor backwards that will unstick the starter if it is stuck.
