420 gas tank
Chris
10-22-2003 21:06:25
Help, I am looking for a gas tank for my 420.. anyone know where i might get one? or a way to stop mine from leaking? thanks
rick
10-23-2003 09:58:49
 Re: 420 gas tank in reply to Chris, 10-22-2003 21:06:25
if it has pin holes you can use a gas tank coat which sells for 25 dollars if it is leaking around the nut insert where sediment bowl screws in then take it to a weld shop they probably have a nuetral gas and can weld or solder it if you got rust and holes and leaky nut first fix nut the coat i sell it if your interested
CPeter
10-23-2003 05:39:23
Try Scott at Maine Tractors. I bought some sheet metal for a 420 from him. What he has is a couple of 40s, but the tank is the same.
CPeter
Wayne in Tn.
10-23-2003 08:04:51
 Re: Re: 420 gas tank in reply to CPeter, 10-23-2003 05:39:23
Chris, the 40 tank will physically fit your 420, but it is different. You will have to use a vented cap, to avoid pressure buildup. The 420 has a vent tube and fitting on top of the tank. The vent tube is supposed to run down beside the engine and clamps to one of the oil pan bolts. If yours is leaking at the seams, you don't have much choice other than get another or take it to a radiator shop for repair.
If it is leaking at the sediment bowl threads or the collar on the bottom of the tank, here is my way of repair: First get a new sediment bowl assembly, they are available at most farm supply or auto parts stores for under $20
Then sand and clean good around where the collar meets the tank, mix up some JB Weld and put a good bead around it with your finger. Then coat the threads of the new sediment bowl with the JB and screw it in before it drys. Usually those threads are messed up in the tank, It may be hard to ever remove the sediment bowl, but a new one should last many, many years, before ever having to remove it again. I have some tractors that have not seeped any gas at all, (On the new paint job) after several years of doing this.
CPeter
10-23-2003 15:34:13
 Re: Re: Re: 420 gas tank in reply to Wayne in Tn., 10-23-2003 08:04:51
According to the parts manual, the change to vented tanks did not occur until serial number 126977, so you could use a non-vented tank, even if it was a later machine, just use the vented cap like Wayne says. Replacement tanks for earlier tractors were the later vented style but used a pipe plug and vented cap and were not vented with the vent tube.
