Deere Crawler questions
Brent in MO
08-24-2004 16:53:48
I have a small JD crawler that does not have a serial number tag on it. It is a 3 roller, looks like either an MC or a 40C. It has an M64 engine. What is the easiest way to ID this crawler for certain? Is there a serial number stamped somewhere on the tractor? Thanks for any help.
Karen
08-25-2004 04:50:05
 Re: Deere Crawler questions in reply to Brent in MO, 08-24-2004 16:53:48
One way you can tell is the grills. They have two different ones...the 40 has a grill screen like a 420. The MC has horizontal slats like an M.
Greg S
08-24-2004 19:46:06
I would suspect that it is an MC because of the three roller configuration. The serial number for an MC should be on the plate located under the gages on the dash. I believe that the first MC's started with a serial number around 10,000 and that the last serial number is around 20,000.
CPeter
08-24-2004 17:50:01
third party image
On an MC the serial number is located on the dash lower center. On a 40, it would be on the left side front of the center frame just behind the connection with the motor. There is a number on the motor which sort of relates to the serial number range, but without contacting Mother Deere through the dealer, it doesn"t give you the exact serial number. Todd"s website has a lot of information on this subject.
Brent in MO
08-24-2004 20:11:41
 Re: Deere Crawler questions in reply to John Van Va1kenburgh, 08-24-2004 17:34:29
Thanks so far. I knew where the plate should be, but it is gone, so I am looking for some other way to identify the crawler. I know that there were 3, 4, & 5 roller 40C's. How would I be able to tell if it is a 40C or an MC?
Richard Hay
08-24-2004 21:06:03
 Re: Deere Crawler questions in reply to Brent in MO, 08-24-2004 20:11:41
I own a 40C and from what I can find the on the difference on the appearance is the grill piece. The 40 C has a heavy plate installed in front of the grill. My serial plate is also located on the left side of the gear case below the sediment bowl.
Lavoy
08-25-2004 10:41:35
 Re: Deere Crawler questions in reply to Richard Hay, 08-24-2004 21:06:03
40 has a fan shroud, MC does not. 40 throttle lever is heavier and is right at dash casting, MC sticks out 6" or so from the dash. MC has a cast dash with the serial number in the center by the ignition switch, 40 has a steel insert in a cast dash, serial number tag is on LH side of center frame. 40 has only a PTO, MC has PTO and flat pulley, or at least the hole for the flat pulley drive to insert into. MC has cast drawbar, 40 has 3 piece flat strap drawbar. MC has straight shift lever, 40 has bent shift lever. There are several other differences, but these should tell you.
Lavoy
Brent in MO
08-25-2004 13:42:25
 Re: Deere Crawler questions in reply to Lavoy, 08-25-2004 10:41:35
Thank alot guys. It looks for sure that it is a 40C. I really appreciate all you help.
