4010 PTO ?
Whitefield
08-24-2004 11:20:29
Okay, I read through all the forum archives, and can't find an answer to my problem. I have the detent pin under the dash fully functional now-(it was frozen in the down position) Thank you MSB. The control rod is adjusted for 3/8 upward play from the home position. When I pull the PTO lever rearward the brake will not apply. With the cover off the bottom of the tractor I can feel the pin which pushes on the brake to engage- this pin still turns freely with the lever pulled all the way rearward. - It seems as though the casting is not rotating far enough rearward to push on the pin. The brake is new. What is out of adjustment here? Thanks everybody.
Whitefield
08-24-2004 13:44:45
 Re: 4010 PTO ? in reply to Whitefield, 08-24-2004 11:20:29
A little more information. The brake IS new- I installed it. Maybe I should add that when the tractor was split I could push the activating pin forward until it was flush with the cast surface of the clutch housing. When I pulled the PTO lever back the pin would protrude about 1/8 to 3/16 of an inch- and that is all. I didn't measure that- it is my best recollection- because I did check to see that it was moving back and forth.
WTW
08-24-2004 12:34:06
If the PTO brake is new, your problem is one of two things. 1. May be so much wear in all the mechanical joints from your PTO lever all the way down to the fork and there is to much lost motion in linkage where it creates a problem with not enough travel in lever movement to make fork travel far enough back to apply pressure on actuating pin. 2. May be due to PTO idler gear that PTO brake shoe is pushed against has move back farther away from PTO brake shoe, caused by thrust shoulder behind idler gear is worn off allowing gear to move farther away from PTO brake. This shoulder is part of the PTO idler gear inner bearing race. Good Luck, DW
ET
08-24-2004 12:17:37
The facing is worn off on the pto brake . You need to split the tractor at the rear of the clutch housing to change it. While your there check the pto shift pins.
