70G head painting
Stu
08-24-2004 09:34:53
My engine is painted, but the head has seemed to burn the paint off to expose the casting. I am looking to re do the paint on a tractor, is there a process or type of paint to do the head this so that the entire engine will hold its paint?
Stu.
Stu
08-25-2004 17:55:36
 Re: 70G head painting in reply to Stu, 08-24-2004 09:34:53
As always, very much appreciated opinions. Thanks...
Clooney
08-25-2004 04:01:04
Stu, those G"s have the exhaust passages passing right along the outside of the head so it�s next to impossible to keep paint on the outside of the heads if the tractor is used very hard..
I checked a while ago for high temp green paint & there didn�t seem to be any out there..
About your only option other than ceramic or other high dollar coatings is to mask it a repaint just before taking it to a show.
[email protected]
720Deere
08-25-2004 10:24:52
 Re: 70G head painting in reply to Clooney, 08-25-2004 04:01:04
Here's a good question. What if you were to use some sort of high temperature paint for several coats and then use your regular paint over it? I am no paint expert, just posing a question.
Clooney
08-25-2004 11:16:29
 Re: 70G head painting in reply to 720Deere, 08-25-2004 10:24:52
720Deere, WELL-- I don"t know how that would work on the head but I can say from experience that it won"t work on the exhaust.. I have been looking for a while now to find some green hi-temp to use on the Dubuque mufflers.. I tried some flat black hi-temp with a dusting of Deere green over it & it soon turned a scorched looking brown then peeled just like nothing was used under it.. I just know someone has to be trying to make a green hi-temp paint as there is a good market for it out there [something about the green pigment & high heat makes that hard to accomplish..
Clooney
jdhbag
08-24-2004 15:34:56
Check www.specialtyexhaust.com they have a process u may be interested in but they are not cheap.
