Fluids for John Deere B 1946
E. Ray Hardy
08-24-2004 07:26:57
I am sure this question has been asked before. I am restoring a John Deere B but it has been 55 years since I left the farm and used one! At my age I have trouble remembering what I had for breakfast. What are the proper fluids for my John Deere B-- Where do I fill each area and where do I check the levels. It has the power trol unit also. I have an IT shop manuel but it doesn"t show specs for oil, hydraulic fluids etc.. Thanks in advance.
Pete
08-25-2004 14:17:47
 Re: Fluids for John Deere B 1946 in reply to E. Ray Hardy, 08-24-2004 07:26:57
To start with what you expected to hear - you should get a copy of the operator's manual which will provide information about fill and drain ports as well as capacities. A quick search of this site will yield any number of discussions about recommended lubricants. The following will work well though there is any number of variations. Crankcase - 10W30 motor oil, transmission/rear end - GL-1 mineral oil in 90W or 140 W depending on temp and use, Powertrol - JD Hygard or 10W30 motor oil, Power Steering (if applicable) - JD power steering fluid. If the operator needs some lubrication - I recommend Summit Amber Lager or Pale Ale.
E. Ray Hardy
08-26-2004 14:54:53
 Re: Fluids for John Deere B 1946 in reply to Pete, 08-25-2004 14:17:47
Hi Pete,
Thanks for the info.
I know I should have an Operator"s Manual but I am old and poor so: Buy the manual or buy the fluids. On second thought maybe I should forget the manual, forget the fluids and buy Amber Lager and Pale Ale. Have a good day.
