Packing for gas tank switch over valve
KEV
08-23-2004 19:05:18
I have a dual fuel 1941 "B" Just wondering if anybody has or can get the packing that goes in the switch over valve.This valve switches from one tank to the other
Thank you
Clooney
08-24-2004 04:43:50
 Re: Packing for gas tank switch over valve in reply to KEV, 08-23-2004 19:05:18
KEV, as Matt said Deere should still have that packing.. It"s just a cork seal..
If your valve has a lot of wear the tapered valve might be in too deep & that partially covers the flow holes plus removes tension from the seal area.. If that valve is excessively worn you might want to consider a new one..
You can clean your internal valve up with a light buffing with steel wool or a very fine Scotch pad but don�t sand on it or go at it with a rotary wire brush or you can elongate the internal holes & or make the tapered valve seat so deep that it bottoms out & won�t shut-off properly..
Adding a little white grease to the cork when reassembling helps it turn easier & if the valve taper is worn sometimes adding a second brass washer over the cork can help the sealing a little.
[email protected]
Matt_In
08-23-2004 19:06:43
My Deere dealer has them in stock.
KEV
08-24-2004 17:23:24
 Re: Packing for gas tank switch over valve in reply to Matt_In, 08-23-2004 19:06:43
Matt
Do you have P/N.
Checked with 3 deere dealers and they can only get the whole valve.The valve looks good so I was hoping to get the cork only.
Thank you!!!
