Hints on Removing Camshaft Drive Gear on JD H
Blksmok
08-23-2004 18:45:09
Helping my brother replace a bent camshaft on a 1945 JD H. Manual tells which assemblies to remove, no problems. Then it simply says to detach drive gear from camshaft. Easier said than done. Anyone have suggestions, tricks, techniques on how to remove the gear once the left hand bearing assembly is removed?? Tried using a brass drift pin and moderate level of heat (MAPP gas), but it hasn't budged yet. Thanks!
Clooney
08-24-2004 04:50:38
 Re: Hints on Removing Camshaft Drive Gear on JD H in reply to Blksmok, 08-23-2004 18:45:09
Blksmok, those usually either just fall off due to being run loose or can be a real pain..
I have tried pullers & heat but so far the best thing I have found is a piece of 1-1/2� or so round steel about 3� long that I drilled & tapped the end for camshaft thread size. I only drilled it deep enough so it bottoms on the cam end before it touches the cam gear.. I heat the cam gear hub plenty hot, then screw that driver on, then pry out on the gear while giving that driver a few good swats.. That usually works [at least so far]..
[email protected]
