1972 0r 73 John Deere 820 transmission overheating
Cleatus Little
08-23-2004 16:56:03
This tractor runs great, but recently the hydraulic pump at the front of the tractor broke its shaft and my implement immediately fell. No problem fixing the shaft, but since then if I raise the lift I hear the normal internal whirring noise. But the noise does not stop, as it used to, even when the lift is let down and the transmission gets so hot in 15 minutes that the shifter boots begin to smoke.
When the tractor is started, it can run forever and be used for anything as long as I never raise the lift. Once that lift is raised, I must turn off the tractor in 15 minutes due to overheating.
Can anyone please point me in the right direction as to what is wrong and how I can correct it? Thanks!!
david val
08-24-2004 02:45:26
 Re: 1972 0r 73 John Deere 820 transmission overhea in reply to Cleatus Little, 08-23-2004 16:56:03
there is an internal leak in the rockshft system. probably from piston seal or valves. rockshaft assembly must be removed for repair.
david
Jay Fain
09-02-2004 12:27:30
 Re: 1972 0r 73 John Deere 820 transmission overhea in reply to david val, 08-24-2004 02:45:26
The rockshaft has been rebuilt. The overheating problem went away. The tractor can still be used to operate a finishing mower, but when trying to use the Bush Hog, the lift oscillates at high frequency. After a few small rounds of cutting, the lift raised the cutter all the way up. The lever could put it up or down, but could not control it at cutting depth. Also, while lifting, there is still a bad noise. When the lift is down, all is quiet. Any more ideas?
