Clooney, Others - Keep breaking clutch bolts '49 J
RayP(MI)
08-23-2004 16:43:59
Over the past two seasons, I have broken 4 of the special "T" bolts that pull the clutch assembly together when the clutch is engaged. All four broke while running a baler, last year an Oliver T60, this year a New Holland 268. Thought that perhaps the rythm of the baler might have had something to do with it, but with two different balers? Baling and moving bale wagons are about all the service tractor sees anymore. Have replaced clutch disks, and have been very careful to adjust the bolts to equal tightness, and not too tight. Torque all three to the same tightness, and then back off all three the same number of turns. Have adjusted to so that I get a good but light snap when clutch is engaged, or disengaged. Have replaced each broken bolt with a used bolt, and all I can figure is metal fatigue. All bolts broke just below the nut on the threaded part of the bolt, which is a reduced diameter. Any ideas as to what is happening here? I sure hate to replace with new, at almost $50 each! My supply of used has dried up. Any suggestions appreciated!
Mike M
08-24-2004 17:33:39
 Re: Clooney, Others - Keep breaking clutch bolts ' in reply to RayP(MI), 08-23-2004 16:43:59
Sorry to hear your still haveing trouble. I remember you from before.It is no help but your problem I think is very rare as I have parted out a lot of old A's and B's and worked on more than a few and have yet to see a broken clutch bolt. I have seen broken clutch dogs and worn out threads. I can offer a few suggestions that I would try next. Buy the new bolts from JD,make sure you have the clutch assembled right,example a faceing next to each metal plate and no two metal surfaces next to each other.Then what I think may be the key is to tighten the clutch so that it requires 70 to 80 pounds of pull to disengage as I think this is what the book calls for.Just a light snap may not hold it tight enough and let it slip a wee bit when the baler jerks on it. Also when tightening those adjusting nuts I use a beam type torque wrench to get all three even pressure somewhere around 10 to 15 foot pounds will usually do it.Also did you put in a brand new center faceing ,the one with the metal plate sandwiched in the middle and the three holes that slide over the bolts ? Surely your not the only one to run a baler with a 1949 B. Good Luck.
RayP(MI)
08-25-2004 06:43:54
 Re: Clooney, Others - Keep breaking clutch bolts ' in reply to Mike M, 08-24-2004 17:33:39
Mike,
Thanks for your reply. Clutch is assembled correctly, by the book, although I can see how someone could make that mistake. After 4 different incidents of breakage, I'm getting pretty good at removing and installing clutch assembly. I too have been using a beam type torque wrench to initially tighten bolts - usually to 20 ft/lbs, then back off all three nuts the same number of turns, or fractions of a turn to get proper engagement. Last time, I replaced both disks with new, and the center one (with the holes,) with a like new salvaged disk. (Am told there is no after-market supplier of these.) All my old disks seemed to be in good shape, although center one didn't have a lot if wear left in it. Have new JD bolts on order, should be here tomorrow - at $51 EACH, that's gonna hurt! Also ordered the cone shaped washers Clooney recommended - $ .70 each. Will give them a try. Talked with the service manager at the dealer too, and he's at a loss to figure out what's going wrong. Clutch doesn't seem to be slipping while pulling baler, even with a wagon load of hay behind. Last year's baler, the Oliver didn't run very smoothly, but the New Holland that I'm using now seems to be pretty smooth on the drive line, and not jerking the pto. Ray
Mike M
08-25-2004 09:15:33
 Re: Clooney, Others - Keep breaking clutch bolts ' in reply to RayP(MI), 08-25-2004 06:43:54
Sounds like you have done everything right and then some. I'd just also tighten it up so you get a good loud snap.
Clooney
08-23-2004 17:31:44
Ray, you say your problem is on a '49 J.. I presume that is a mis-type.. Most of the time those bolts shear off just under the nut it is due to twisting the bolts due to frozen adjusting nuts. If that isn�t the case then it could be anything from sharp edge holes in the outer adjusting disk, to excess wear on the inner plates allowing the outer plate to pull more than it�s share of the load,, to rust on the outer adjusting disk allowing it to grab & do too much work,, to a lot of slop in the clutch plates allowing the clutch pulley to rotate against those bolts through the drive disk.. If your tractor is a B you might try the later 520-530 conical washers under the nuts as that allows a smoother engagement & less bolt strain.. There was a bolt change on some of the tractors to improve the fit in the pulley holes but with your breakage outboard farther that probably wouldn�t help you any..
One last thought�make sure the nuts aren�t going on those bolts so far that they are bottoming on the thread shoulder & fracturing the bolts at the threads..
[email protected]
RayP(MI)
08-23-2004 18:11:22
 Re: Clooney, Others - Keep breaking clutch bolts ' in reply to Clooney , 08-23-2004 17:31:44
Yes, I titled it a '49 JD B, and title got cut off. All have broken in the threaded area below the nuts, so I'm not pulling the bolts too tight, and running nut beyond threads - bottoming out. Replaced all friction disks last time, as they were wearing thin. All metal plates are smooth, clean and not rusty. As best I can tell, the bolts break while clutch is engaged, and tractor is pulling, not on engagement. I'm at a loss as to where to go here. Thanks, Clooney
