720 diesel throttle lever
steve duplechin
08-23-2004 15:45:45
My throttle control lever will not stay in position. The friction disk have worn out and need to be replaced. I went to the John Deere dealership and they do not show a part number for just the friction disk. Has anyone run in to this problem and what have you done to solve the problem. I looked at some friction disk from another type of trottle lever and they look like they may work. How many disk do you put? Thanks for your help.
Ron L.
08-25-2004 16:25:07
 Re: 720 diesel throttle lever in reply to steve duplechin, 08-23-2004 15:45:45
Deere offers kit # RE227852. Parts man said he could not tell what it consisted of. $ 43.00. He said he would order one and I would not be obligated to purchase it.
Blksmok
08-24-2004 07:39:31
Steve....I think the part from JD is a cast iron piece with the friction material bonded to the metal. I recall it as being kind of expensive. I buy a gasket material called "karropack" from our local auto parts store and cut the two required disks from that sheet stock and then tighten the nut and compression spring as required to get the right friction to keep the throttle in the set position. I'm sure other material will work, but this sheetstock is readily available and cheap.
Gerry
08-24-2004 05:27:56
A year ago I changed the one in my 720 gas. Just called the dealer and asked for the part. It was not a problem as far as I knew. It was about 35 bucks if I remember. Cleaned ( sanded ) the dowels and holes, made sure the springs were good, added a little oil and put it back together. Works great.....
Joe P.
08-24-2004 04:45:10
I also have seen a piece of leather cut to fit and it worked well.
msb
08-23-2004 20:36:32
It is a good idea to check to see if the dowel pins will bottom out while you have it apart.Have seen some that didn't and it gave the appearence of a fiber washer being worn out when it was not.I like to polish up both parts and coat them with neverseize(A little Dab will do ya)
Hilltopper
08-23-2004 18:37:41
I found the # Af3849R. This was $70.60 4 years ago. I priced but did not buy.
720Deere
08-23-2004 18:20:38
I took one apart once that had a cutting disc from a 3" air cutoff tool. It seemed to work pretty well. Also hear of people using leather. I guess the bottom line is basically anything that will fit in there and create friction will work.
TPat
08-23-2004 17:10:55
Steve, I have had good luck with cutting friction disks out of an old conveyor belt. I have done several this way. All are working as they should.
