Gas Line Leak
Dan 41B
02-03-2004 12:21:59
What would be a good sealant to put on the threads of the gas line from carb to bowl assembly? I've tried teflon tape and that doesn't seem to seal very well. Any suggestions would be appreciated.
Clooney
02-03-2004 13:10:32
 Re: Gas Line Leak in reply to Dan 41B , 02-03-2004 12:21:59
Dan, by far the best pipe thread sealant I have used or found is Loc-Tite PST with Teflon.. That stuff seals excellent, doesn't migrate into the carb, stays fairly soft, isn't effected by alcohol or other fuel additives & is easy to apply..
~I agree with Bob in that you should look closely at the solder joint between the line & end fitting as sometimes the solder starts to deteriorate with some of the additives in the newer gasoline's.
~If your fittings are distorted you can apply a little Loc-Tite PST to the back side of the end fitting & on the male threads of the fitting & that will even seal up a distorted fitting..
~I am strongly opposed to using Teflon tape on any fuel fitting as the tape can get torn as the fitting is screwed together & that can work it's way into the needle & seat & cause a leak or even a fire, or work it's way into a jet or passage..
[email protected]
Bob
02-03-2004 12:55:32
Use a gas-resistant pipe thread paste sparingly on the threads of the adapter, where it screws into the carburetor, making sure none gets on the first thread, or so, and finds it's way into the carburetor. Tighten the fitting firmly and adequately in the carb, and then hold that fitting with a second wrench when you tighten down the fitting nut.
Are you referring to the Deere-type fittings, where the bullet end is silver soldered to the steel gas line? Sometimes this solder joint can crack and leak, so if you have a leak with fittings such as this, with the fittings properly tightened, check out the solder joint.
John T
02-03-2004 12:50:26
Dan, First of all, I no longer use or recommend any sort of Teflon Tape in the carb or fuel system since I saw how it can separate and clog things up in the carb, plus talked about it with Robert Beaver a few years back. If you're talking about the lines and fittings Im thinking of (NOT pipe type threads), they seal with compression and shouldnt have any reliance on the threads anyway. If cleaning and smoothing the line ferrules and fittings dont seal, you might try Permatex No. 2 to seal between the line and outside of fittings, but on some of those type lines, it seems once they get distorted or non concentric they wont re seal.
Anywho, dont use teflon tape, try to smooth/clean/round the fittings and maybe try Permatex or a better sealant intended for gasoline like a Loc Tite product. They really shouldnt require any sealer if they are not distorted.
let us know
Good Luck n God Bless
John T
CRUSADER
02-03-2004 12:43:44
I usually use Teflon thread tape. I put about two wraps around it and very seldom have any problems. If it is a real problem and still leaks, you may check the integrity of the threads. On a few occasions I have put a rubber O-Ring on it between the flange and the nut and this stopped the leak. Good Luck, and hope this helps.
