Flywheel casting A2448R ???
Jason Z in MO
08-23-2004 07:36:25
Found a fly wheel with casting number A2448R. It"s off a hand start tractor and by the size of it I am guessing an A maybe a G.
Can anyone confirm?
Pappy
08-23-2004 22:20:42
 Re: Flywheel casting A2448R ??? in reply to Jason Z in MO, 08-23-2004 07:36:25
Just realized that you are talking about a casting number instead of a part number. If you look closely at the flywheel, you will probably find the casting number to be A2449, not A2448.
A2449 would be a flywheel for the "A", serial number 488000 thru 583999. Sorry I didn't think of this before. Old age, you know.
Jason Z in MO
08-25-2004 07:36:34
 Re: Flywheel casting A2448R ??? in reply to Pappy, 08-23-2004 22:20:42
Pappy,
Good news - you are correct A2449R
Bad news - I am getting older and my eyes are failing!
Thanks for everyone"s help!
Jason Z in MO
08-24-2004 06:55:03
I will rub a wire brush over it tonight and find out if my eyes are failing too!
I checked some prices, I guess my $25 wasn"t so great after all!
Pappy
08-23-2004 20:22:54
Part number A2448R is a clutch driver. It will fit Model "A" from Serial Number 488000 to 647999.
JDTracker
08-23-2004 19:21:08
I am sure it is to an A, but when I looked up A2448R it showed it as a Clutch Drive Disc for an unstyled AR and AO...hummmmm mm????
Mike M
08-23-2004 10:04:44
John Deere used to be very good about thier number system in most cases the prefix told you which type tractor.In this case the A meaning model A if you had a F it Could fit a model G,70,720 a B would go to B's I don't have my parts book handy to find out exactly which year A it is for.But it is not for a G.
Jason Z in MO
08-23-2004 10:51:47
 Re: Flywheel casting A2448R ??? in reply to Mike M, 08-23-2004 10:04:44
Mike,
Thanks for the good information. I should have know that. I guess I was only hoping for it to fit a G.
I was at the Power of the Past show in Greensburg IN this past weekend and found this flywheel on the ground. I didn"t have any way to positively identify it but it was not cracked and the splines are in good shape. I ended up buying it for $25. The "Old Threshers" group I belong to has a G with a cracked flywheel. I didn"t think it was as thick as the flywheel on the G but knew it was too large for a B so I took the chance.
I don"t think I got hurt either way.
