4630 Fuel Filter LEAK
pbutler
08-23-2004 05:49:06
I had my 4630 Idling in the shop yesterday when one or both (can't exactly tell) of the fuel filters started dripping fuel down to the ground. It wasn't so much of a drip as almost a steady stream-a LOT of fuel.
I quickly killed the tractor and after grabbing the fire extinguisher and holding my breath everything seemed ok. When not running it doesn't leak but the minute I start it the fuel starts flowing out again.
Hopefully it is something as simple as a plugged filter or something. I checked the lines in and out the filters and didn't see anything obvious.
Has anyone else ever seen this problem?..or have an idea what would have caused such a big leak so quickly?
luckydog
08-23-2004 15:57:58
 Re: 4630 Fuel Filter LEAK in reply to pbutler, 08-23-2004 05:49:06
Glass filters will start leaking (Deere defect) as I was told by my dealer. They recomend useing the metal filters, they bond together better because they are made for high pressure systems of the newer Deeres. luckydog
WTW
08-23-2004 09:16:18
The common cause for glass filters leaking was cracking of glass or pushing glass from bonded base caused by the pulsations from transfer pump located on the side of injection pump. Normally these pulsations are absorbed by the soft rubber located between the filters and inlet of injection pump. When this line get old it gets hard and does not absorb the piston pump pulsations from transfer pump resulting in leaking and broken filters. The new line will sub over to a different part but is there for the same purpose. Pretty simple fix if that is your problem. Good Luck, DW
david val
08-23-2004 07:48:37
could be cracked glass, bad glass to metal base sealing, bad rubber seals at the back of the filter or high line pressure due to bad relief valve (the banjo screw on the right of the pump) clogged return line or bad anti drain (one way) valve at the filter base.
david
