730... Gas, or Diesel?
Scotty
08-22-2004 23:34:36
If buying a tractor to use on the farm almost everyday; would the gas be better, or the diesel? I prefer Diesel; But more importantly I prefer a tractor that starts, & runs everyday! Any thoughts out there?
Scotty
08-23-2004 20:23:09
 Re: 730... Gas, or Diesel? in reply to Scotty, 08-22-2004 23:34:36
Just would like to add some info!
A 400 acre farm in which the smallest tractor on the farm is 160hp as of recently. I really want a 2 banger for some smaller jobs, & for use in hay! I have several small fields that I cant hardly even get into with larger machinery; So looking at some smaller equipment; But keeping the larger equipment as well!
720Deere
08-27-2004 07:44:01
 Re: 730... Gas, or Diesel? in reply to Scotty, 08-23-2004 20:23:09
Scotty,
If you are looking for a "work" tractor, then I would be looking for an electric start diesel. As stated before, they don't make the best chore tractors, but are unbeatable as a working tractor. If used on a regular basis the fuel economy difference will pay for any cost differential real fast.
Soldier Tom
08-23-2004 15:55:33
I like my 720d'sel. The pony start will crank in cold cold times, and the fuel economy is nice. How big a farm are you working, and what are you going to be using it for? Just curious. ~Walk in peace~
720Deere
08-23-2004 14:40:27
The diesels don't make a very good chore tractor. The were meant to more or less have their guts worked out all the time. Electric start diesels are very convenient, but terrible to start in lower temperatures. On the other side of the coin, the 730 gas will probably burn twice as much fuel as the diesel, but unless it is going to do steady, heavy work I wouldn't worry about economy.
I love the diesels and they would always be my first choice. The biggest downfall of the diesel is that most of them have been worked hard and need quite a bit of attention. They can be costly beasts to work on. I would say that it would be a toss-up. You should go with the one you are most familiar and comfortable with.
Mike M
08-23-2004 07:21:37
To use almost every day a gas one will use too much fuel and a diesel one you may end up working on it more than using it. You would be better served with something along the lines of a 2510,2520,3010,3020,4010,4020 depending on how much horsepower you need. If you must use a 2 cyl. than the 620,630 would be a better choice for all around usefullness unless thet are too small ?
