Hydraulic Lift Question on JD 2040 Tractor- Please
Sam Adams
08-22-2004 20:02:08
Hello,
I am having a problem with my 2040 John Deere Tractor. The hydraulic lift will not stabilize and keeps going up or down like a 9N Ford. I've checked the fluid level and it's okay. Don't really know what else to try.
Any suggestions? All advice appreciated.
Thanks,
Sam Adams
Tatum, Texas
david val
08-23-2004 07:59:19
 Re: Hydraulic Lift Question on JD 2040 Tractor- Pl in reply to Sam Adams , 08-22-2004 20:02:08
it could be an adjustment problem. make the step by step adjusment bas describe in the tm.
it could also be a leak in the cylinder seal or valves (if such a leak exists, when engine is off the lift arms will drop pretty fast). or other internal valve or linkage problem. these require rockshft assembly removal.
david
Gpower
08-23-2004 07:56:42
Hey Sam,
Sounds like internal problems, either the rockshaft piston, or the hitch valve. Does the pump sound like it is working all the time?
Gpower
