4440 Cab Fan Problem
Rex
08-22-2004 19:55:56
My cab fan quit working. I replaced the circuit breaker and relay. It would work a while and go off. Later it would work again. I replaced the blower motor and the resistor next to it. It worked for about 5 minutes and quit again. What else do I check? or do I just call a mechanic?
david val
08-23-2004 08:41:12
 Re: 4440 Cab Fan Problem in reply to Rex , 08-22-2004 19:55:56
if you have a resistor, you probably have the later, one motor design.
with a test lamp, with the key switch on and the bower swich off, check for voltage at the blower switch bat terminal. ( if i remember well it's the one with the red lead). if there is voltage (the test light showing bright light), turn on the blower swich with the test light at the same spot, see if the light fades considerably or vanish. if it does, it may be overloading by the motor or bad wiring check wiring especially at the connector under the right front end of the cab (you need to remove the sheet metal panel connected to the battery box). if it seems okay, remove the roofs and try to rotate the motor with your fingers, the motor should rotatae freely and have no radial play.
if motor seems okay try to run another 12 volt motor from rhe motor connector to load the circuit. if the other motor works fine, your motor is bad. if the other motor behaves like your original, you have a problem with your wiring.
if after the first test the light remains bright check for volage and ground in the motor leads. if power and ground are okay, the motor needs replacing ( usually worn collector and brushes).
if there is voltage coming to the swich and no voltage at the motor leads ( in all speeds) the swich is bad.
you can get to the blower switch from under the inner roof or by removing the ac plastic cover from the roof and removing the swich with leads attached and pulling it in (make sure key swich is OFF!!!). david
Rex
08-23-2004 18:25:17
 Re: 4440 Cab Fan Problem in reply to david val, 08-23-2004 08:41:12
thanks. i printed your instructions out and I'm going to give them to my mechanic. he was out this morning and found a corroded blower fan connector on the top of the cab on the right side (someone had stuffed a small piece of copper wire in the slot). the blower fan worked fine at all speeds this morning but this afternoon after about 10 minutes on high speed it shut down again. i have a new blower motor, resistor, circuit breaker, and relay-but no air conditioning yet.
Roger H
08-22-2004 21:31:02
Rex, are you talking about the relay & breaker down by the clutch pedal or something else? I had ALL electrics quit in the cab lately so I replaced the relay below the 2 rows of breakers, everything ok since, parts man also told me, if the tractor had aluminum strips to connect the one side of each row of breakers, replace them with copper strips, he also said that the nuts over the aluminum strips may be loose which would cause problems too.
Rex
08-23-2004 04:41:57
 Re: 4440 Cab Fan Problem in reply to Roger H, 08-22-2004 21:31:02
Roger H.
yes, the realy and switches by the clutch pedal. I will check for alum vs. copper. don't think the nuts are loose, but I will check.
thanks
msb
08-22-2004 20:57:48
Just a guess,but I would ssuspect a wiring harness problem.Its about time for a tractor of that age for the connections to go bad.
Rex
08-23-2004 09:31:29
 Re: 4440 Cab Fan Problem in reply to msb, 08-22-2004 20:57:48
msb,
a connector on the main blower wire located on the right front of the cab was corroded and someone had put a small piece of copper wire in the connector. took out the quick fix piece of wire, cleaned up the connector and so far the blower seems to work fine on all three speeds and takes 12.5 amps.
thanks
Rex
08-23-2004 04:43:56
msb,
Thanks, I will check the wiring harness. Guess I should have done that first before I started taking suggestions about changing parts..
