Belt info
Greg
02-03-2004 10:54:09
Hello. I am always looking for new excuses to run a 1944 B. The newest possible reason would be to run an oil well pump jack on an intermittent basis. To do this, two things must be considered. First, a driven wheel of the right outside diameter must be attached to the gear reducer at the pump jack. A local towmotor wheel manufacturer has donated a wheel rim that can be used as the driven wheel. Question #1: It seems that belt driven wheels should have a crowned surface to keep the belts from walking off. Does anybody know the recommended crown taper for such wheels? Too much crown would probably wear out the middle of the belt, and too little crown might not have the desired effect.
The second item that needs to be worked out is the belt itself. I know nothing about belts. Questions #2,3.... Is there a size/length/width that is considered to be standard for use with a B? Do they come in different thicknesses? Are all belts stitched together the same way? Should some types of belts be avoided, and others sought after? Are there any unique questions that should be asked prior to purchasing a belt?
Last question: Are there any good places to get a used belt near Akron, Ohio?
Thank you,
Greg
dan_41jdh
02-03-2004 14:07:57
 Re: Belt info in reply to Greg, 02-03-2004 10:54:09
Greg,
Regarding question #1 - (from an old Machinery�s Handbook): �Belts may be made to center themselves on their pulleys by the use of crowned pulleys. The usual figure for the amount of crowning is 1/8 inch per foot of pulley width. Thus, the difference in maximum and minimum radii of a crowned 6-inch wide pulley would be 1/16 inch. Crowned pulleys have a rim section either with a convex curve or a flat V form. Flanges on the sides of flat belt pulleys are in general undesirable as the belt tends to crawl against them. Too much crown is undesirable because of the tendency to �break the belt�s back.��
Questions #2 & #3: Belts are available in a number of thickness, compositions, number of plies, widths, etc. Unfortunately, they are rather scarce. The major manufacturers, such as Gates and Goodyear, mention them, and will make them, but it appears they are on the way out... One source you might try is McMaster-Carr. Some of their belting appears to be suitable, lets say 6" wide or so, and runs about $3.50 or so per foot. That belting is not endless, and must be spliced. Splice kits are available. Farm auctions might be another place to find belting...
The last question?? Sorry, don't know.
Greg
02-04-2004 05:46:03
 Re: Re: Belt info in reply to dan_41jdh, 02-03-2004 14:07:57
Thank you Dan.
