Correct plugs for 1937 B
Binder-Man
08-22-2004 17:29:23
Is autolite 3077 the right plugs for my 37 B? Thank you for your time and help on this...
Binder-Man
John T
08-22-2004 21:31:23
 Re: Correct plugs for 1937 B in reply to Binder-Man, 08-22-2004 17:29:23
Yep, they (as well as other brands) will work fine, those or the equivalent AC No. 18 work best in my 38 Unstyled Long Frame B. They are a heat range hotter than the Autolite 3076 specified and being the deeper reach side wire electrotode type they seem to last a bit longer before sooting up. If the tractor was in good condition, not an oil burner and you used it for continuous long hot heavy loads, you might wanna use the Autolite 3076, but for lighter cooler n parade duty etc., I perfer the hotter AC 18 or Autolite 3077.
Good Luck n God Bless
John T
Binder-Man
08-23-2004 04:48:55
 Re: Correct plugs for 1937 B in reply to John T, 08-22-2004 21:31:23
Thank you John T for your help, It was all rebuilt about 2 years ago. It is a parade and show tractor now days, I guess you could say the ol girl is retired!! Thanks again John T.....
Binder-Man
