Feeling really dumb about my B
Todd in Indiana
08-22-2004 17:12:59
Just bought my first Deere B. The fellow said it was,nt running but that it had been and was,nt stuck. I put in a new battery and hit the starter and the starter engages but the flywheel does,nt move. Where do I go from here? You guys are a better source of information than a dozen manuals. Thanks in advance.
Todd in Indiana
08-23-2004 04:34:22
 Re: Feeling really dumb about my B in reply to Todd in Indiana, 08-22-2004 17:12:59
Thanks for the information guys. The tractor is a 1949B. It has been converted over to 12 volt with a alternator and coil/distributor. How do I go about turning it over by hand ? The starter gear spins and engages the flywheel but wont turn it. I removed the plugs but still no luck. Any advice?
Sam#3
08-23-2004 17:32:30
 Re: Feeling really dumb about my B in reply to Todd in Indiana, 08-23-2004 04:34:22
Regarding turning by hand. I can relate how the older models were equiped and I always supposed the newer ones with enclosed flywheel were the same. The old electric start JDs came with a tool and a special hub to allow the steering wheel to be used as a cranking device. All the later models that I saw had a small tab in the middle of the flywheel cover which I think was for access to the cranking hub. Findind a suitable crank may be a problem but most any crank should work for just turning it over. Be careful, the JDs can kick!
Tim...OK
08-23-2004 06:32:43
Give her a good squirt of kerosene or similiar in the plug holes,jack up one back tire,put'er in 4th gear and try rockin the back tire back and forth,if'n she's lightly stuck,this should free'er up..if not let her sit with fluid in there for a few days and try again..
HTH...
Tim
Aberdale Farm
08-24-2004 05:06:27
 Re: Feeling really dumb about my B in reply to Tim...OK, 08-23-2004 06:32:43
Todd,
From your description, I believe Tim is on the right track here. If the starter engages but doesn"t spin (assuming the battery is fully charged) then the engine is stuck. Since your B is a "49, put it in 6th gear (high) when rocking the wheel back and forth. Hopefully it only has a light coat of rust in one cyl. and will break free easily.
If you want to get a bit more agressive, you can pull the B in high gear with the sparkplugs out and clutch engaged to try and break it free, then try the starter again.
Be careful!
Dale
Larry806
08-22-2004 20:09:45
Hi Todd What year is the B? When the starter engages does that mean the starting motor is turning? Make sure the ring gear is tight & in good shape My first guess is the starter drive is bad. The good news is that's not a big deal I keep an extea on hand they cost me about 30.00 If you take your starter to a shop they should do it for less than 50.00 Let us know what you find out
CRUSADER
08-22-2004 19:16:37
Todd,
Try turning it over by hand. If it turns easily you know it isn't stuck. Just guessing here, the starter on it is still a six volt. From personal experience it usually took a little more umph to turn that crank over. Remember to open the petcocks prior to trying to start it. This should let it spin over a lot easier. Just a few thoughts you may want to consider.
later days mate,
Jim
