1955 JD 50LP starter question
Kerry
08-21-2004 18:56:39
I've had this problem periodically but it doesn't seem to be fixing itself this time. The starter pedal is sometimes very stiff, like the spring is a lot tighter than normal, when it gets like that it doesn't hit the starter. Other times, if I try it enough times, it will finally go all the way down and hit the starter. I've got the flywheel cover off now, but there's nothing there that indicates the starter pedal/rod is getting in a bind. It doesn't feel like it's binding, it just feels like the spring is very tight.
When it doesn't work (like now...) it feels like the starter pedal spring is VERY tight. Other times, the spring feels normal and the starter works. Sometimes I have to try pushing on the pedal and letting off several times until it goes down right and will start.
I'll probably pull the starter cover off Sunday afternoon to see if I can see what is causing it, do you guys have any ideas?
John T
08-21-2004 21:03:19
 Re: 1955 JD 50LP starter question in reply to Kerry, 08-21-2004 18:56:39
Kerry, unhook a battery cable before you mess much with the starter, cuz thats a big hot feed down there ya know. If the rod or spring isnt binding up somewhere or bent or jammed up, once you get the starter out and remove the switch off the starter that may provide more clues. Look for burned or badly pitted or carboned up switch contacts or a starter post which can explain having to push a few times to make contact. However, that dont explain it being harder to push at times??? unless the starter drive has problems???
If you cant find any external problems (binds or bends or linkage hang ups) then youre gonna have to take a look at the starter drive n switch.
Let us know, Good luck n God Bless
John T
Mike M
08-21-2004 21:00:07
This may be happening at the times when the drive isn't going into the fylwheel and you have to compress the spring on the drive also.
