JD 60 Carb/ Help
Ben.So.Tex
02-03-2004 08:50:04
I was field working my 60 the other day it was doing fine, then it started to cut in and out with puff of black smoke, I got it back to the shed and checked to see if the fuel bowl had any water/dirt, I cleaned it out checked the stream of fuel and it has a good flow of fuel going to the carb, I cranked it up and it will only run about 5 seconds and die, wait a mintue and started it up again and it run about 5 second and died again. WHAT COULD BE THE PROBLEM? BEN
Buckeye al
02-03-2004 13:49:00
 Re: JD 60 Carb/ Help in reply to Ben.So.Tex, 02-03-2004 08:50:04
Recently worked on a 6o doing this same thing. Owner was bush hogging briars & small trees like no tomorrow. All of a sudden it wouldn't mow anything. Was all he could do to limp back to the barn in first & sometimes second gear. Running the mower was totally out of the question! At slow idle it would keep running, it was missing badly & blowing lots of black smoke but it would keep running on only the right cylender. Soon as you put a load on it it would die. Start right back up at idle but if you loaded it, it would quit.
Could be caused by several things but in this tractor's case, the left choke plate screws vibrated out & dropped the left choke plate off of the choke shaft. The air pulled the plate back sort of cockeyed against the venturi leaving the left half of the carb about 2/3 choked. Maybe yours did this same thing?
First I'd verify it's not a spark problem then I'd try removing the casting in front of the carb & take a peek inside to make sure the chokes are operating properly.
Ya never know. Good luck.
Duane Larson
02-03-2004 11:33:16
Ben,
Try checking the spark when it is dying/dead - a coil gone bad could cause symptoms like you describe. Or, if it is blowing black smoke when dying, the float could have developed a hole and the engine is flooded.
old
02-03-2004 11:19:48
Dirt in the main jet probably, if its got a starter on it you might try pulling the intake hose off the carb and holding your hand over that part of the carb and turn it over, some times that is enough to clear up the problem
Ben.So.Tex/ Thanks Guys
02-03-2004 17:01:38
 Re: Re: JD 60 Carb/ Help in reply to old, 02-03-2004 11:19:48
Thanks for the input guys, I took the carb apart and could not see anything wrong, checked all the ports and I could spray cleaner throught all of them,,,,, I have an extra coil I will take it to the ranch tommorrow and see if that could be the problem, and a set of points,,onces again thank you..... Ben
