On the 14th I posted a question about my 60 overheating. I had a few answers but not enough to solve my problem. I looked further back using a search and found the answer from aguy saying to fill it with 70% vinegar and 30% water and running it for about an hour. I did this and much to my amazement it worked better than I ever expected. I ran it for three hours and it never got above 180* even though I used fourth gear instead of third gear I had to use before to keep it from getting hot too fast. He said to run it about and hour but I wanted to see if it would heat up more, it never did. Since vinegar is diluted acid finally ran out of nerve about leaving it in too long and stopped and drained it out. I will flush it out with fresh water tomorrow and run it a few days with water only instead of mixing it with anti freeze.Our well water contains a lot of lime so it just accumulated over the years until it had a thick coat. This was a very welcome solution when compared to the prospect of a new head gasket, head or block. The first thing I did was clean out the radiator fins and screen, then I tightened the belt to the water pump...both with no effect. I wish to thank whoever came up with that idea and I apologize for not copying his name along with his post. He mentioned that he had used this method on an old Oliver so that may be a clue on his identity. At this point I am suspicious that I may have had too much anti freeze or it was too dirty and could have been the cause. I'm going to let the anti freeze sit a few days and see what settles out on the bottom. My radiator fins were about 50% wiped out by a fan years ago and the system is unpressurized but it still has run cold all these years unless the shutter is closed for the first hour or two. Obviously this radiator is way overbuilt or it may be from a larger tractor. Needless to say I am very happy to have solved this problem and that Ole John is back working for me just like it has for 23 years. This is a great forum!!
