Holy Cow! Cracking wheels on the 60
Fred from MO
08-20-2004 19:17:11
Ok this is very odd..I removed one wheel from my 60 by the book with no problem. Loosened up the 3 large outer bolts on the wedge, and the 3bolts on the back of the wedge with the cut out for the pinion gear and used the jack bolts to push the wedge out-no problem. Did this again on the other side of the tractor and cracked the wheel in half from the hub out. Wow! We had been soaking the wheels for weeks in PB blaster. Miffed by this, I got another wheel from a salvage yard. Sandblasted, painted my one good original wheel, all the wedges to make them look new. Installed the salvage yard wheel on the axle wih no problem. Installed the remaining good original wheel on the other axle. Started the outer 3 bolts on the wedge with the keyway first, then the 3 bolts on the back of the wedge with the cut out for the bull gear. When using a ratchet to snug up these bolt, the last good original wheel cracked from the hub out just like the other from earlier. Has anyone seen this happen? What would be causing this? The bolts were not very tight when the wheel let loose on this side. Is is possible my old tractor came from the factory with 2 bad cast wheels or am I missing something here? The wheel was jacked up with NO weight on it when it cracked. I used antiseze on the bolt threads, I would not think that this would cause the wheel to crack.? Bull gears in each wheel were free and turning. A buddy of mine has changed several wheels off of tractors and has never seen them crack like this? I have another wheel from a salvage yard to put on it and do not want to have another costly repeat.
Mark1
08-22-2004 20:20:01
 Re: Holy Cow! Cracking wheels on the 60 in reply to Fred from MO, 08-20-2004 19:17:11
If anybody wants to replace a broken hub, - I have hubs for sale, F1500R, they are $75 each. Email for more details.
Mark
Don c
08-22-2004 12:56:31
Have read on here where the wheels with the oval windows have been know to be a lot worse to crack then the round windows. Mine is a early 60 with the oval holes, so far so good on mine. Never did hear why this was.
Don c
Nich
08-22-2004 08:58:01
I am at the moment trying to move my wheel with no luck - Please Help they are solid!
Thanks
fixerupper
08-21-2004 09:57:53
My 630 has an 8" crack in each wheel. Maybe I have over-tightened the hubs some time in the past. I have heard of this happening before on numbered series Deere's.
Mike M
08-21-2004 05:19:32
I have seen several of these cracked.I had some crack on me ,but I think this was because of them being heated to free the pinion. I never heat them anymore. When tightening I don't use too big of a wrench or go to tight all at once. Tighten them up some then drive a little retighten repeat once they are tight they will be seated in and you won't gain anymore on them. If they are loose you will hear them pop when going from forward to reverse.
ET
08-21-2004 05:07:43
Was the crack a new one or was there a hairline crack in the wheel already? John Deere does not recamend anti seize on the wedges but the bolt threads should be ok. You need to be careful on the old castings because the lub. on the threads inceases the clamping force, for the power aplied to the wrench.
Russ
08-21-2004 17:22:21
 Re: Holy Cow! Cracking wheels on the 60 in reply to ET, 08-21-2004 05:07:43
Wedge issue; Nothing more powerful than a wedge.
Your JD 60 hub/wheel removal procedure must be followed with great care. May have been casting defects, undetected, which failed due to the high stress sequence being applied. Bummer of course.
Fred from MO
08-21-2004 06:27:07
I did heat up the wheel to free the pinions. I only put antiseeze on the bolts and greese on the wedges and axles. Thanks for the replys
ihjdmike
08-21-2004 07:35:54
 Re: Holy Cow! Cracking wheels on the 60 in reply to Fred from MO, 08-21-2004 06:27:07
I split a wheel on my 60, but the jack bolts were stubborn and I used a 3/4 impact wrench to help. It turned the bolts without much problem and the wheel popped like an m80 going off.
