2355 still having problems
chris
08-20-2004 11:17:39
Hi, thanks to all that answered my last post. I have done the compression test, tested and changed all the injectors, changed the lift pump, and filter again. Still no power, it almost seems to be worse, now when it gets hot it will not start. Could the timing be off? When i reinstalled the pump I lined up the marks on the outside the way they should be, the only thing that could of happen is somehow maybe the motor got turned while the pump was off. How do you set the timing where it should be on these motors? Another thing when it is idleing it almost seems ot ping like a gasser out of time. The only thing I have not done is set the valves. I am getting very frustrated with this am about ready to ship it to the dealer. Any help anyone would have would be greatly appreciated. Thank you Chris
david val
08-21-2004 04:23:48
 Re: 2355 still having problems in reply to chris, 08-20-2004 11:17:39
if it is a stanadiyne pump you have to have the timing pin in it's hole in the flywheel, make sure it' on #1 tdc, and have the lines under the timing window on the pump align.
if it's a lucas/cav pump, and since your engine starts and work,it may be one or two teeth off. you can try trial and error by royating the pump's gear a tooth or two in both directions.
another way to change the timing is to remove the timing cover and retime the timing gears (cover must be removed anyway if you can't rotate the pump's gear from the outside.
if you want to make sure your'e out of timing requirs a comlex job involving a snap ring in the pump to be aligned with a mark on the body when # 1 injection stoke is begining (a diesel shop job). then the engine must be rotataed to the begining of injecton angle ('static advance'). then the pump must be set through the window on the side with the snap ring end (the flat end lining up with the correcrt mark for #1 (a stamped letter signifise the cylinder # on the rotating group, ask your diesel shop for the correct letter. or in some cases look for the letters close to the injector openings on the pumps head)
when all this is done look for alignment of tht key on the pump shaft with it's groove in the gear (older models had a pin on the three bolts pump drive flangh and a slot in the gear.
if you need more information on the letter finding post here or contact me. the degrees are not marked on the engine pulley you must mark the pulley yourself on tdc and begining of injection by translating the pulley circumference to 360 deg.
david
chris
08-21-2004 12:18:49
 Re: 2355 still having problems in reply to david val, 08-21-2004 04:23:48
Thank you David for your reply, I have the cav/lucas pump. I took the pump off and I think I see the problem. The key-way was only half in the slot(side to side) As hard as it is for me to beleive, it looks like when the big nut on the gear was tightned it just suck it in and quished the key way in there. The shaft was off one way about a 1/8 of a inch. I can not get the key-way out now, hopefully the shaft is not ruined. When I put it back, if for some reason it is still off time, can i just turn the flywheel so the timing gear moves one tooth, or does the gear have to come out and rotate it. Thanks alot for your help it was greatly appreciated. Chris
david val
08-22-2004 00:22:28
 Re: 2355 still having problems in reply to chris, 08-21-2004 12:18:49
i was under the impression that the pump was removed because of the power problem. anyway, if you want to change the pump gear position, you should rotate it by itself. you can try this from the openings, but most likely it will be impossible without removing the timing cover. the violent force of starter operation may "jump a tooth" when operating the starter with the pump out.
from what you describe, the key was scisored. usually this happens while using excess starting fluid when starting the engine. since the timing on this pump is external, you can rotate either the engine or the pump in order to align the key with it's groove.
david
