Henry, as a retired electrical engineer and camper of many years, I have fought that very same problem and been concerned with it electrically speaking for a long time. Those molded 30 amp "rated" RV plugs n receptacles, unless brand new and having very tight receptacle contacts, seem to heat up when you pull even 20 amps or so through them. I always keep my plug terminals sanded/polished clean n bright and spread open in between if any are the split type BUTTTTT the weak link problem is usually in the receptacle which is sealed/molded and you cant get into. As posted below, any loose or low contact area mating between the plug n receptacle can cause high resistance and even resistive carbon build up WHICH CAUSES HEAT. What has worked for me, and since its the receptacle NOT the plug that causes many problems, is to buy a weatherproof cast aluminum box and install a good grade 30 amp 3 pole RV receptacle inside it, then use the watertight box n cord connections PLUS a light coat of silicone at the joints. Those more commercial box mounted RV receptacles seem to have better quality contacts (than the cheaper molded end receptacles) that retain their tension when plugs are inserted into them. Its also better if you use solder to tin the wire lead ends then install them into the receptacle terminals. Of course, they are a bit heavier n bulkier with that big box on the end, but when Ive replaced the cheap molded receptacle cord ends with an aluminum box and mounted receptacles I have built myslef, the heating problem has went away. The 30 amp RV cords Ive seen for sale always have the molded ends, so thats why I build the receptacle ends myself. The molded types seem to work fine when new, but once oxidized or worn and resistance builds up due to poor plug/receptacle contact, the old heat problem is back. Let us know, post back or e mail me at [email protected] any questions. Good Luck n God Bless John T in Indiana
