B power steering
uglyold A
08-20-2004 06:56:56
I've got an older farmer who could really use p/s on his 49 B . Appearance isn't real important - function is . Any advice would be great - george
Jake
08-20-2004 21:05:34
 Re: B power steering in reply to uglyold A, 08-20-2004 06:56:56
You should check other things first. My 1950 B had brinneled bearing races on the worm gear. This is grooves that the bearing rollers wear into the races and makes things lock up. Also check for worn or broken steering gears and maybe the thrust washers at the bottom of the pedestal.
I do not recommend any power steering on a B because I've seen enough of those gears worn and broke when they do not have power steering attachment.
Hayfarmer
08-20-2004 07:22:38
About the only thing I can think of to do this would be to use a char lyn in shaft unit. Would need to have power steering pump also or live hydraulics. You can sometimes find the units on e bay but not cheap
Hayfarmer
08-20-2004 07:22:51
